Another First - 1/35 CH2 TES.
  • Scratchbuilder
    • Jul 2022
    • 2689
    #181
    Originally posted by Waspie
    B*gg*r!!!!:angry::angry::angry: I was so keen to get the primer on I forgot to mask off the commanders windows!!!! As a result I have about 7 or eight transparent bits that are primed.
    Is there a cheat or any way to remove the primer before recommencing!!!
    I did read somewhere, coat with IPA and leave for a few minutes before trying to remove the paint - any truth?
    No pics as I was pretty annoyed. On the plus side I did manage to prime the hull and turret, only the side armour to go!!
    Must learn to slow down!!
    Use the cocktail stick dipped in IPA as Pete said. Remember which finger to scratch your eye with.....
    • JR
      • May 2015
      • 18273
      #182
      The reason they are not allowed to carry arms is that decades ago the rookies from a certain regiment went through one of the villages and decided to get rid of all their unused blank ammo which included thunderflashes, drove the villagers under their beds and gave the local coppers red faces of rage...... I sem to remember our next training area was Dartmoor...
      Wibble hope we're not you involved in such a dasterly deed.
      Wobble
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        #183
        That worked a treat!! (Well a tiny plastic spatula did). I tried the airbrush cleaner but that was only a partial success. Left it a while, returned to attack with IPA and hoorah!!!
        That led to my next problem!! After cleaning the airbrush twice last evening I found it was splattering when I went to use it today - so I stripped it down again and instead of using airbrush cleaner to give it another going over I thought I'd use IPA after the success with the clear stuff!! That seemed to do it - fluid coming out of the nozzle. Problem now was I ran out of time.
        How come life is so busy when you're retired?? Not enough hours in the day at the moment.
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          #184
          My bad….yes, that’s exactly what I meant. Vallejo airbrush cleaner. It’s far better for jobs like that than it is for cleaning airbrushes
          That I found out today!! It's got to be good for something!!!!
          • Scratchbuilder
            • Jul 2022
            • 2689
            #185
            Been retired for 7 years, and never stopped since, at least in the truck I could jump on the bunk and snatch a couple of hours kip while unloading - jump on the bed in this house and you get another job.....
            • spanner570
              • 15441
              #186
              .........as the actress said to the Bishop!
              • Waspie
                • Mar 2023
                • 3488
                • Doug
                • Fraggle Rock
                #187
                My Sunday job, (repairing the bath), turned into a Monday job!!!! However, I still managed to whack, (sorry - another technical term), some more primer on. Always remembering to thoroughly clean the airbrush afterwards. Glad I took pictures as I notice I still missed a couple of places.
                I also remembered to coat the commanders glass with liquid mask before redoing that part of the turret. Methinks I will just follow advice on here and not run before I can walk and stick to the paint scheme supplied. Afterwards, I can start thinking about playing around with weathering.
                Another dopey question. The primer I am using Vallejo 'polyurethane' primer. I believe is the reason my airbrush is behaving as it is, clogging!! Or is it me? Are other primers different?
                Anyway, a few pics.
                A couple of place on the turret roof will need priming - brush for that methinks!!
                Another small patch on the spool at the rear!!
                Lots learned doing this, next time I do some armour there are definitely a few things I would do differently. Order of spraying/fitting etc. Attention to track parts!!! Definitely more to this modelling lark than there was 40+ years ago!!!
                Hasn't put me off - still enjoying it even though it has been and still is a bit of a 'challenge'. (Oooo - that's bad):rolling:
                  • 18932
                  Looking good in primer Doug.
                  As to the Vallejo stuff, I’ve found it needs thinning a bit and a couple of drops of flow aid to work well without clogging. It’s just too thick to spray properly straight out of the bottle. Not my favourite primer though.
                  • langy71
                    • 1950
                    • Chris
                    • Nottingham
                    #189
                    Totally agree with Tim on this, tried it a few years ago, it's still sitting in my shed..unloved... switched to good old Halfords grey primer..works like a dream..
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      #190
                      Thanks Tim, Chris. After this experience I think it will be the last time I use it. Certainly in airbrush form. I did mix a bit up and brushed it into the places the airbrush/ME!!! missed!! Oh Tim, I did 'thin' it a bit, I used distilled water rather than tap water ss this area is a seriously hard water area.
                      Had much planned for today! Finish the priming. Put a first coat on then tracks then finish working on the 5 gall water and fuel cans for the rear stowage!! First coat of Nato Green is/was planned for tomorrow. Just to allow plenty of time for the primer to cure properly. (Evidently the green is mixed with white in a ration of 90% to 10%.)
                      I achieved? Finishing the primer!!
                      That's it!! No more!! Zip, zilch, nada, sweet FA!!!!
                      SWIMBO intervened - again. The joy of emptying all the kitchen cupboards, cleaning them, putting all the contents back. After checking every single 'Use by' date!!! I know she's asthmatic and hates dust, I can live with it. It's the last minute disaster planning!!!
                      I even volunteered to search for her logic circuit board and replace it. Declined!!
                        • 18932
                        The VJ primer works best with their airbrush thinner and flow aid rather than tap water in my experience Doug. Sprays fine then, but I don’t like it because I can’t sand it afterwards if I need to do remedial work later. I find it just tears under the paper.
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #192
                          Good info. there Tim. I always use an enamel base as it "bites" into the plastic a little for better adhesion.
                            • 18932
                            I use a lacquer (cellulose to the Brits) based primer for exactly the same reason Rick. It sands to a feather edge as well.
                            • Waspie
                              • Mar 2023
                              • 3488
                              • Doug
                              • Fraggle Rock
                              #194
                              I actually managed to have good day today. No chores, just a whole day with a paint brush. I have decided to give the airbrush a rest, only in that I decided it may be good experience giving the brush some exercise!!!
                              Started with the tracks, a few coats of Mig Track Black, which is more a rusty brown to my eyes but who am I. Followed by a tea break then attacked with some suitable rubber coloured paint. (I say that because I forgot the colour!!!!) Three coats applied to the rubber blocks. After that - more tea and decided on order of painting for the actual vehicle itself. Nato Green with a splash of white as per the instructions. I'm rather glad I decided to brush paint rather than A/B. Lots of nooks and crannies that I found were difficult to access with the primer.
                              A few pics of todays progress.
                              After second coat of the track blocks. Bottom track dry, top track still slightly wet, one more after that!!
                              First rough coat of nato green, (barrel has had a second coat applied, simply to use up the last drops on the palette).
                              Closer pic of one of the tracks (3 coats on rubber blocks), I have experimented with a drop of a rust coloured paint on the link ends but tbh, I can't see any difference!
                              Won't get any bench time tomorrow, which will give the paint a good while to dry properly. For some reason they say to paint the platform sand colour! No idea why but that shall be done!!
                              I see there is some tidying up of the tracks, between the links which will be addressed next time a window of opportunity pops up.
                              Quite a pleasant day what with achieving something, cups of tea and music whilst I brushed. Roll on next chance!!
                              One thing for Jakko, since you pointed out the link connectors having some upside down!! They stick right out now I know!!! Something I won't forget for the next armour with linked tracks!! Thanks for that! :thumb2:
                                • 15746
                                Just had a good catch up, Doug, and you're doing a great job. I don't like Vallejo primer for the reason Tim gives, it doesn't sand to an edge.
                                As for weathering a model. Despite there being hundreds of "must have" products desperately trying to part you from your money there is little that can't be achieved with oil paint and pigments.
                                Keep up the good work.
