Sd.kfz.7/1
  • Mickc1440
    • 4775
    #61
    Superb detailing Scottie
    • scottie3158
      • 14201
      • Holbeach
      #62
      Originally posted by Graeme C.
      Great detailing there Paul, the pipes on the engine could be part of the coolant transfer system for cold weather starting. There's something on the wing which looks like the outside part of it.
      Cheers Graeme sounds good.
      • scottie3158
        • 14201
        • Holbeach
        #63
        Cheers Mick.
        • scottie3158
          • 14201
          • Holbeach
          #64
          This will be the last update for a while as This will be put to one side as I will be starting the lorry group build tomorrow.
          Front towing pin fitted with loops and chain.
          cheers
          Scottie.
          • Scratchbuilder
            • Jul 2022
            • 2689
            #65
            Plaudits all said, just sitting here admiring your work and attention to detail.
            • scottie3158
              • 14201
              • Holbeach
              #66
              Its been a while since I did anything to this, as I have been building the GMC for the group build.
              The engine has been finished off along with the bulkhead and Instrument panel. I haven't done a lot to the drivers compartment because once the cab has been fitted you will be able to see precious little inside.
              cheers
              Scottie
                • 15687
                Nice looking instrument panel but as you say very little will be seen in that armoured cab. Have you decided whether the engine will be on show?
                • scottie3158
                  • 14201
                  • Holbeach
                  #68
                  Jim, I think I will leave the side panels off to show the engine as it is nicely detailed.
                  • Nicko
                    • Apr 2019
                    • 1402
                    • Nick
                    • East Anglia
                    #69
                    I'd forgotten about this one Scottie. Nice to see it back on the go.....
                    Nick
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #70
                      You Go Mr. Scottie....like what I see and hear! :thumb2:
                      • Andy T
                        • Apr 2021
                        • 3239
                        #71
                        That engine looks a treat, I'm glad your planning to have it on show.
                        • scottie3158
                          • 14201
                          • Holbeach
                          #72
                          Nick
                          Cheers Nick.
                          Thanks mate.
                          At least it should add some interest.
                          • scottie3158
                            • 14201
                            • Holbeach
                            #73
                            I intend to have one of the cab doors open. As the kit one was very thick and not well detailed I fashioned a new one from some styrene sheet. The rivets were added from pewter, you may have noticed that the middle two rows of rivets have been removed as they are not shown on my reference pics. The new door handles were made from copper wire and the window shutter slides from plastic sheet finally the catch on the shutter from brass sheet.
                            the bottom rail still needs a little cleaning up.
                            cheers
                            Scottie
                              IIRC, there were two types of cab: one with doors and side walls bent from one piece, and another that had them fabricated from two flat pieces of steel, riveted together.
                              • scottie3158
                                • 14201
                                • Holbeach
                                #75
                                Jakko,
                                Looks like I'm going for the bent one :smiling:.
