Early Scimitar.
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    #46
    Update,
    The build of the vehicle is now all but finished....
    [ATTACH=CONFIG]n1207852[/ATTACH]
    [ATTACH=CONFIG]n1207853[/ATTACH]
    All that needs to be added is the start of the Cam net...
    [ATTACH=CONFIG]n1207854[/ATTACH]
    Net taking shape...
    [ATTACH=CONFIG]n1207855[/ATTACH]
    And tied down.
    This will be allowed to dry for 24 hours as the net was soaked in a water/pva solution so it would keep its shape once dry.
    Next job will be masking and priming.
    Mike.
    Love the orange flashy light on the turret.
    • scottie3158
      • 14201
      • Holbeach
      #47
      Superb mate.
        • 15692
        You're definitely a master at this super detailing lark.
          That net looks very convincing. What’s it made from? The mesh seems to large to be a piece of bandage soaked in glue?
          • Scratchbuilder
            • Jul 2022
            • 2689
            #50
            It's from 'Fields of Glory Models' code FOG5000B. And it is so much better than the bandage and once the painting is complete then I add the little green and brown bits for the camo net...
            like this... (old Accurate Armour Chieftain).
            • Scratchbuilder
              • Jul 2022
              • 2689
              #51
              Many thanks for the comments.
              Jim, that is what happens when you get dragged into the dark side..
              Doug, some old 'winky-wink' lights from AA bought many years ago and just remembered, went through a whole cd cover the other night trying the push mould just one!!!!
              • JR
                • May 2015
                • 18273
                #52
                WOW
                Up to your normal build quality Wibble .
                Wobble still busy on 1/1.
                • David Lovell
                  • 2186
                  #53
                  Totally in awe ,a absolute pleasure to follow thanks for sharing this brilliant. Dave
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #54
                    Update,
                    Primer coat went on, but it might have been me or the primer as there seemed to be a lot of dust around, but not to worry.
                    This was AK 3rd gen black primer. I forgot to mask the 'winky-wink' light and the pic was taken just after I had cleaned of the primer with some airbrush cleaner.
                    Top coat was next, first a coat of SMS CARC Green, followed a couple of hours later with some SMS CARC Black....
                    The cam net was then dry brushed with some brown, although it does not look brown in the pic, and the rope used to tie it down was Hemp. Yoy can see some of the bits I mentioned earlier on the glacis plate and turret top, again this is enlarged due to the photo. Now it is going to be decals and detail painting.
                    Mike.
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      #55
                      Update, update,
                      Since my last post I have given the 'rough' parts a light rub with some 3000 paper and it seems to have cured the problem.
                      Mike.
                      • Si Benson
                        • 3572
                        #56
                        Looking good there Mike
                        • David Lovell
                          • 2186
                          #57
                          Looking great ,shame all the hard graft has disappeared but it still looks something special love the netting. Dave
                          • De.Mort
                            • Aug 2023
                            • 83
                            #58
                            Can i just say .. apart from the excellent work .. people like me learn from what's posted .. i can copy .. i can't do original stuff .. i've tried .. but copy is good for me as i learn .. thank you .
                              • 15692
                              Looking good Mike. The roughness of the primer coat is strange. Do you think something has settled on the wet paint or is it bits in the paint itself? I don't think the current high temperature makes airbrushing easy.
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #60
                                Then copy away, no foul and a pleasure to teach you. If you need any help with a process, please feel free to ask, even a PM will get a reply.
                                Mike.
