Rick's 1-87 Scale Trident Jagdpanther Conversion
Well,here we go again!!...
... As usual, I've missed the more recent updates... BUT...
... That really is looking the business buddy... BRING ON THE REST OF THE CAMO!!Comment
Current progress on paint repairs and adjustment of camo pattern. also some detail painting of the tracks.....tried something new, Tamiya panel line accent (brown) I washed the tracks with this stuff then when dry I went over them lightly with Steel lacquer (Testor's) and then did a little highlighting with a silver Prisma colored pencil. I still need to complete the detail painting and weathering of the inner tracks and roadwheels before attaching the outers.Comment
Current progress on paint repairs and adjustment of camo pattern. also some detail painting of the tracks.....tried something new, Tamiya panel line accent (brown) I washed the tracks with this stuff then when dry I went over them lightly with Steel lacquer (Testor's) and then did a little highlighting with a silver Prisma colored pencil. I still need to complete the detail painting and weathering of the inner tracks and roadwheels before attaching the outers.[ATTACH=CONFIG]n1207397[/ATTACH][ATTACH=CONFIG]n1207398[/ATTACH][ATTACH=CONFIG]n1207399[/ATTACH]:smiling5:
Sorry I'm in so in late Rick, but I have been following this Kitty build all along. For that scale, the tracks are fantastic and really detailed. You've done a fine job bringing them to life with the colors!!! I wouldn't worry too much about correcting the camo Bro, as I don't think the 9th has any Rembrandts in their ranks back then...Great work Sir!!!
AllenLife's to short to be a sheep...Comment
Thanks Allen, Sorry if I confused you about the camo, what I was talking about is the amount of overspray that manages to find itself in areas where the dinkleglib is supposed to beI repair those areas by stippling with a yellow dry brush to eliminate or at least reduce the amount of overspray. Because the model is so small, the camo bands are very close together and even with the air pressure at a minimum and the paint thinned to the consistency of water it still happens. I have learned that the drybrush stipple method allows for good color separation and still keeps the edges soft. As to the tracks, I'm pretty pleased with how they turned out but I will continue to experiment as I think they play a key role in creating a more realistic model.
Thanks again for the kind words.:thumb2:Comment
