Churchill AVLB #2
But read the instructions and LOOK :nerd: at the parts (see update below)....Comment
Damn Olderthanme, it doesn't look like you had a good day with the CA, now did ya!!! I guess it happens from time to time and glad to hear you got the fingers free... Can you save it or do you have to de-bond the plates and redo them Mike? Not too up on the bridge things. She is/was looking good though!!! You'll be okay...
YoungerthanyouLife's to short to be a sheep...Comment
Youngerthanyou
OlderthanyouComment
I know what you you mean Olderthanme...I glued the the rear deck on my Kübelwagen upside down and wondered why the rear seat had a huge gap between it and the deck cover. I started hacking the seat up to get it to fit, when I finally looked at the destructions and saw my error. DOH!!!...Lotsa TET finally got it apart and I glued it on correctly. Be damned, the seat fit fine to the deck now!!! Old age really sucks Mike!!!...Life's to short to be a sheep...Comment
Is that bridge made from lasercut sheet, like some other parts in IMA kits? The SBG assault bridge I’ve got, has some of those too. (I ask because to a modern eye, it will also look like 3D-printed translucent resin)
And if you believe that then you really do need the care home....Comment
Yes Jakko it is from laser cut acrylic sheet and the fit is really good, the second (correct) one I cut out and put together last night in about two hours with no fit problems at all. I would like to see more of the mainstream producers look more into this method and product. And if memory serves me right there was one of the 'cottage' OO railway producers that issued rail carriages in this material.Comment
I haven’t built the SBG bridge because, well … the AFV Club one came out, but the material is very well-suited to flat bits that would be difficult to cast in resin (or clean up when they are cast in resin) and difficult to assemble in etched brass, I would think.Comment
The laser cutter is perfect for flat things,much better than being cast in resin in a flexible mould. It's always baffled me how manufacturers employ only one technique to do everything, it's almost like the process comes before the subject, rather than the other way round.
At least we are now seeing some injection moulding manufacturers addin PE where appropriate (admittedly for a fair few years now)
I recognise that cost is a factor obviously but in the case of resin and after market stuff you may as well use the best process. That said, I had a laser cutter in my job but it cost thousands to buy, whereas now the prices have come right down to a couple of hundreds,so maybe we'll see a bit more laser cut stuff appearing in the next few years?Comment
Update,
The build is now complete, the correction to the mistake with the treadplate is now rectified...
And no! I did not put each piece on seperatly, it was thin strips of 20thou cut about the same width and then c/a used as the cement and when dry went along and cut off what was not required (the gaps)...
As I said the build part is now complete, going to start on the primer and then base coat...
At the left hand side of the bridge tread, it is laid out correctly...
And it dows work, all the way through the launch process. And today is track making day....
MikeComment
