Warrior IFV with a few bits added
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    #31
    Update,
    Nearly at the join together point in the build, so a copuple of pics before I forget.
    [ATTACH=CONFIG]n1209755[/ATTACH]
    [ATTACH=CONFIG]n1209756[/ATTACH]
    [ATTACH=CONFIG]n1209757[/ATTACH]
    Next it will actually building the vehicle....
    Mike
    Can I see punka Louvre's in there!! Attention to detail is brilliant. Of course the real coup is the bog roll!!!! An army may fight on its stomach but the waste has to go somewhere!!! (Doesn't it????) :flushed:
    • Scratchbuilder
      • Jul 2022
      • 2689
      #32
      Originally posted by Jakko
      Is a toilet roll part of the normal equipment of a Warrior? :smiling3:
      Try sitting in a locked down 432 when all that was available was an empty lemonade bottle, a carrier bag, and government issue tiolet paper.... buying your own was a luxury.
      • scottie3158
        • 14202
        • Holbeach
        #33
        I can't recall being in any Army vehicle that didn't have a roll of Army Form Blank in it some where.
          • 15709
          That's a stunning interior.
          • Waspie
            • Mar 2023
            • 3488
            • Doug
            • Fraggle Rock
            #35
            It was a long time ago but!! I'm sure one of my ex Army workmates showed me a publication for 'squaddies' regards the use of; 'bog roll, soldiers for the use of'!! Or Defacating al la Pongo!!!! Am I imagining it or did such a document actually exist!!!!
            Personally sticking ones stern section over the side of a ship was the navy way!!!
            • Scratchbuilder
              • Jul 2022
              • 2689
              #36
              • Mickc1440
                • 4779
                #37
                Just caught up with the great work you’re doing
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  #38
                  Question - why this reply twice ????
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #39
                    Update,
                    So the hull halves are now joined, no real problems that three hands could not have solved - so while getting the front end glued the rear panel developed a life of its own... But not a real problem as the c/a actually helped lubricate it into place once the clamps were put to use. Left for a few hours and then went to work with the fillet/putty to fill in the few gaps and to re-profile the top of the door opening and roof profile, this was left overnight to dry and then sanded down.
                    Next it was time to do some work on the turret...
                    This is the main centre turntable and ammo box storage and all fitted to the lower turret plate. Still more work to do here including adding the boxes to the inside of the turret itself.
                    Some etch grills added along with some homemade tie downs ready for the shovels....
                    Here you can see two of the three new mudguards fitted with part of the last one still attached to the fret in the lower right of the pic. And now time for a break...
                    Mike.
                    • scottie3158
                      • 14202
                      • Holbeach
                      #40
                      Up to your normal high standards mate.
                        I wondered about that too. First I thought you had forgotten you had already posted something in the same vein, but then I compared the two and they’re word for word identical, so I figured you hadn’t posted it twice yourself. Some kind of glitch in the forum, I guess? Maybe because John’s tinkering with stuff to facilitate changing it to different software in a while?
                        • Scratchbuilder
                          • Jul 2022
                          • 2689
                          #42
                          Update,
                          So a bit more work done on the hull and more work carried out on the turret...
                          Testing the turret turntable for fit....
                          The innards of the turret with the seats in the background still to be added, plus smaller handles etc..
                          The replacement Rarden barrel...
                          And a dry run to see if it fits...
                          And then it will be on to this....
                          With these.....
                          Mike.
                            You must really love bar armour, given how many models you build that have it
                            • Scratchbuilder
                              • Jul 2022
                              • 2689
                              #44
                              You must really love bar armour, given how many models you build that have it :smiling3:
                              It's only three completed up to now, hope this illness cures soon... But there is a LAV-III with bar armour..... (not in my stash - yet!)
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #45
                                Update,
                                Sorry Jakko, forgot I had this one in the stash....
                                Anyway back to the build...
                                I started off adding the turret periscopes, and after cutting them off the sprue further inspection revealed they would be a lot of work...
                                So the second option was to use the etch ones but I got a problem of the very thin lens/front not bending true and flat.
                                So the final option was to scratch build my own, but I would use the etch covers...
                                So the 'periscope part was cut from the cover part and discarded. The cover was then bent to shape and attached to the turret.
                                The 'gaps you can see are in fact filled with c/a and once dry sanded to shape as were the scratch periscopes...
                                I have also been working on the large front sights and added those...
                                Just a bit of cleaning up required ready for the mesh screen later in the painting.
                                The headlights have also had some attention paid to them - I bored out the plastic front and after painting the inside 'Chrome Silver' I will add the light bulb and lens.
                                And finally here are a couple of pics to show the progress so far....
                                Mike.
