Dragon 1/35 sd.kfz.184 Ferdinand
  • Si Benson
    • 3572
    After a string of modern stuff and a couple of 1/100 builds, I decided it was time to rummage around in the stash and find something.
    A quick look into the box and a flick through the instructions and the deal was done.
    Picked this up from eBay over 10yrs ago. The previous owner brought an Aber barrel with muzzle break which I found in the box.
    Heres what you get….
ID:	1211606Click image for larger version
ID:	1211607Click image for larger version
ID:	1211608Click image for larger version
ID:	1211609Click image for larger version
ID:	1211610Click image for larger version
ID:	1211611Click image for larger version
ID:	1211612Click image for larger version
  • Si Benson
    • 3572
    Made a start on the under gubbins….
      Another vehicle on my “would really like to build” list, so I’ll be sure to follow your version instead of adding to my own stash
      • The Smythe Meister
        • Jan 2019
        • 6248
        Nice!!
        I'll tag along too Si, looking forward to it :thumb2:
          • 15687
          Looks good Si. Lots of plastic and Dragon instructions - you could be at it a while. I'll settle down and watch with interest.
          • adt70hk
            • Sep 2019
            • 10409
            Good to you blogging this Si!
            Looking forward to your working your magic.
            ATB.
            • David Lovell
              • 2186
              I'm in Si looks a nice kit ,separate links and some etch to play with nothing else to ask for ,she's a size I bet when built just make sure you've enough of the runny stuff don't want to run out just as you get to the end. Dave
              • BattleshipBob
                • 6792
                • Bob
                • Cardiff
                Count me in Si, interesting but flawed vehicle
                • Mini Me
                  • Jun 2018
                  • 10711
                  Looks like a fun project Si........with plenty of "tidbits" to keep you busy.
                  • Si Benson
                    • 3572
                    Good evening all,
                    Well the Ferdi seems to of drawn a few eyes, hoping not to disappoint then!
                    Great to have you all along :smiling4:
                    Carried on assembling the suspension bogeys…… Glad to report no problems so far!
                    The suspension was a Porsche design and quite different from the german big cats.
                    The kit can be modelled with them in full range if required…
                    All six are then mounted onto the hull.…
                    Hopefully more tomorrow.
                    cheers
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      I'll tag along if I may. Can't do anything myself at the moment due to the weather and recuperating from the other half's 'list'!!!!
                      • Si Benson
                        • 3572
                        The more the merrier :smiling4:
                        • Si Benson
                          • 3572
                          A little more done tonight with assembly of the front and rear drive sprockets and at this point the instructions says to assemble the track…..so naturally I skipped this for now and carried on with the assembly of the rear hull
                          The wheels are just dry fit so they can be removed for painting. The front sprockets have an off centre hub which always helps with track fitting.
                          for its age it’s not a bad kit so far.
                            • 15687
                            Good progress Si. No problems so far.
                            Originally posted by Si Benson
                            ....at this point the instructions says to assemble the track…..so naturally I skipped this for now
                            Coward :smiling:
                            • Si Benson
                              • 3572
                              Coward :smiling:
                              Yup :smiling5:
