Dragon 1/35 sd.kfz.184 Ferdinand
Looks like Apple Dorset cake (as my daughter used to call it). Yummy……Ferdinand is looking good as well…..Comment
Managed a bit more time at the bench adding all the bits to the casement such as hatches and handles.
Dragon gives you the option to model the hatches open or closed and I reckon with a bit of care you could have them moveable . The part count is quite high but not unpleasant to assemble .
starting to look like a Ferdinand now :smiling4:Comment
Right up to the last few bits now. The Aber barrel and muzzle break went on as did the pistol ports complete with plugs on chains a travel lock and other bits and bobs…..
Just a tool box, tow cable cables and of course the tracks to make. I’ll scan through the destruction one last time to make sure I’ve not missed anything then crack on with the tracks…
looking good! Not sure if tool box was moved around the back on some Ferdis. Are you going to use kit tracks?Comment
The kit comes with magic tracks so will be using them :thumb2:
Cheers Scottie :smiling4:
Me or the ferdinand :smiling5:
Cheers mate :thumb2:Comment
Thanks Tim, I hadn’t picked up that it was one of the things altered during refurbishment…..thanks for the info :thumb2:Comment
:smiling5:
Well as you know I’ve got a deal with the modelling pixies….. they do them for me when I go to bed and all I have to do is make a sacrificial offering of PE to the carpet monster :smiling4:Comment
