Dragon 1/35 sd.kfz.184 Ferdinand
  • Si Benson
    • 3572
    #61
    In between taking little one to a birthday party, the weekly shop and a trip to the local model railway shop with the bigger little one….managed to get the base paint on.
    • Si Benson
      • 3572
      #62
      Not much bench time for me this week but managed a little today and began masking for camo scheme….
        • 15696
        Looking good Si. Masking looks fiddly. I don't mind masking up but I hate removing it. Too much stress to see how much bleeding under the tape there is. I'm sure yours will be fine :thumb2:
        • Si Benson
          • 3572
          #64
          Cheers Jim,
          Ive been going round the edges of the tape with one of those silicone tipped brushes, rubbing it down firmly and I’m using bits of blue tack where the tape meets a tricky area so fingers crossed I don’t get too much bleeding under the tape :thinking:
          • Andy T
            • Apr 2021
            • 3239
            #65
            I do love a bit of fancy masking.
            • stillp
              • 8093
              • Pete
              • Rugby
              #66
              Originally posted by Si Benson
              Cheers Jim,
              You probably know this trick Si, but Squirt some of the base colour first, so if there is any bleed it doesn't show.
              • Si Benson
                • 3572
                #67
                You’ll know only too well it’s all in the prep with masking so I’m using my best concentration face when applyin…..
                ……:smiling5:
                Pete, turns Out I didn’t know that trick so thank you kindly, I’ll be sure to try that :thumb2:
                • David Lovell
                  • 2186
                  #68
                  Blimy Si you had me thinking for a bit rember the little zvezda 72nd one I built ,couldn't remember using masking tape or silly putty (hope you don't mind a pic)
                  Then the light went on i used masking fluid pretty sure did the whole thing yellow masked up with the fluid and squirted the green looking back now would have made a better job the other way around still looks like yours is a bit big for this way of doing it ,good to see it making it way to the airbrush though. Is the little bison next up ?you do realise I won't stop haggling about that one. Dave
                    Some progress on the Ferdinand…..
                    Both left and right tracks completed and removable for painting.[ATTACH=CONFIG]n1213353[/ATTACH]
                    those tracks are awesome - are they the same as the Jagdtiger ones? Because they look tricky
                      They’re not the same, Porsche Tigers had their own unique type of track. Jagdtigers had two different types, one from Porsche and the other the same as on the Tiger II, depending on the suspension fitted.
                      • scottie3158
                        • 14201
                        • Holbeach
                        #71
                        Si,
                        Looking very good indeed.
                          thats good to know (although I was making no quotes) as the Dragon Jagdtiger track links look crazy:
                          [ATTACH=CONFIG]n[/ATTACH]
                          • Si Benson
                            • 3572
                            #73
                            Hi Dave,
                            I did like your 72 nd elefant/ferdinand, you made a cracking job of that
                            I had planned on just free handing camo but when I saw this scheme I knew there was no way I’d get it neat enough.
                            As to the Bison, well I seem to of misplaced it :thinking:……I got a little 1/100 Pz III on the go if your interested
                            • Si Benson
                              • 3572
                              #74
                              All credit to dragon Magic tracks, they went together trouble free :thumb2:
                              • Si Benson
                                • 3572
                                #75
                                Si,
                                Cheers Scottie:smiling4:
