Dragon 1/35 sd.kfz.184 Ferdinand
  • JR
    • May 2015
    • 18273
    #91
    Thanks Jakko .
    • The Smythe Meister
      • Jan 2019
      • 6248
      #92
      Originally posted by Si Benson
      Been adding some weathering over the last few days. Think I’m getting there.
      Still have the recovery cables to put together and paint up.
      Haven’t even thought about the tracks yet:flushed:
      [ATTACH=CONFIG]n1214678[/ATTACH][ATTACH=CONFIG]n1214679[/ATTACH]
      Blimey, just caught up with this Si...
      ...looking superb mate, very nice indeed mate
      • Si Benson
        • 3572
        #93
        Originally posted by Jakko
        The engines didn’t need to be synchonised, as they drove electrical generators like Si mentions: the petrol engines just provided the electrical power that went to the motors which actually powered the vehicle — just like in a modern hybrid electric car.
        In any case, if two (or more) engines are mounted to the same crankcase, they work fine with a bit of decent design work. The M4A2 Sherman (and its derivative, the M10 gun motor carriage in your latest diorama), for example, had two diesels attached to a common crankcase, and was considered pretty reliable. The M4A4 even had five engines on a single crankcase and ran fine.
        One tank in which two engines caused much more trouble, though, was the Whippet from the First World War: in that, each engine drove one track. The idea was that the vehicle could be steered by changing the RPM of one engine only, or by speeding up one while slowing down the other. In practice, of course, it’s just about impossible to have both running at exactly the same RPM, so the driver was constantly busy tinkering with both to keep the vehicle going in a nominally straight line.
        Not sure of the reason for using a sprocket at either end, but only driving one, though. The front one was mounted on a crank, so it’s basically just an adjustable idler with teeth on it.
        Thanks for the info Jakko :thumb2:
        • Si Benson
          • 3572
          #94
          Cheers Andy :smiling4:
            • 15696
            That's looking very nice So. I hope the running gear doesn't cause you any problems.
            • Si Benson
              • 3572
              #96
              Thanks Jim :smiling4:
              I’m also hoping for a headache free final fitting of the tracks and wheels ! :flushed:
              • JR
                • May 2015
                • 18273
                #97
                Si I've said it before but can't see you ever having problems fitting tracks.
                • Mini Me
                  • Jun 2018
                  • 10711
                  #98
                  Been awhile since I looked in last. That is looking the Bomb Si! keep it coming Sir. :thumb2:
                  • Si Benson
                    • 3572
                    #99
                    Cheers Rick, glad like her :smiling4:
                      Yesterday evening, I was doing some light reading in Schwere Jagdpanzer: Entwicklung – Fertigung – Einsatz by Spielberger, Doyle and Jentz, and on page 60, happened across this diagram of the Porsche Tiger’s driveline:
                      [ATTACH]498543[/ATTACH]
                      It would have been almost identical in Ferdinand, other than the generators and petrol engines being in the middle rather than the rear (Fahrtrichtung meaning “direction of travel”, so the arrow points to the front), and the petrol engines being twelve-cylinder types instead of ten like here.
                      I can’t quite make complete sense of it, largely because of unfamiliarity with the symbols used, and not helped by it mixing electrical and mechanical systems in one drawing, but the lettered bits in the legend translate as follows:
                      G Generator
                      O Petrol engine (“Ottomotor” is a common German term for this type of engine, after Nicolaus Otto who is said to have invented this type of engine)
                      E Electric motor
                      F Drive switch
                      R Regulator for generator’s external power generation [R is not actually in the drawing]
                      U Field reversing controller
                      M Controller for motor’s external power generation
                      T Electric turret drive [not present on Ferdinand, obviously]
                      The positions of the two levers are:
                      0°: Full forward speed
                      61°: Start of external power generation
                      100°: Complete short-circuit of main power coil
                      154°: External power generation at full strength, start of reverse normal power generation, application of hydraulic brakes
                      254°: Maximum brake position, full reverse speed
                      I: Generators I and II parallel
                      II: Starter generators I and II
                      III: Driving using generators I and II in series
                      IV: Driving using generator I
                      V: Driving using generator II
                      Notice, though, that there is something inside the idler wheels at the front of the vehicle. I first thought these might be electrical, but after studying the drawing and legend more, I think they are the hydraulic brakes that are mentioned for pulling the driving levers back 154°. This would explain the need for sprockets rather than plain idler wheels: without teeth on the idlers, they wouldn’t brake the track very much at all, just the wheels. But with teeth, these brakes will help stop the vehicle completely.
                      On the next page are some diagrams comparing the Porsche Tiger’s steering to that of the Henschel design, and though it’s even harder to make sense of, what they do make clear is that when steering, the electric motor on the side being steered to, was switched to become a generator at some point — I think with the lever between 61° and 154°.
                      Aside from all of this, the stats table at the end of the book also makes clear why all of this was not a great success. Not only would it need huge amounts of copper for the generators and electric motors, but a quick comparison with the Jagdtiger shows it even needed more petrol even though the Ferdinand was lighter: Ferdinand held 1080 litres of fuel and could do 150 km on the road with that. Jagdtiger, despite weighing 6.5 tonnes more, could do 170 km on 860 litres …
                      • Si Benson
                        • 3572
                        #101
                        With Christmas out the way and all the decorations packed up and back in the attic I can finally get back to the where I left of with this beast.
                        Finished weathering the wheels and have now fitted the tracks permanently. They where painted up previously so now just need weathering.…
ID:	1216167Click image for larger version
                        • BattleshipBob
                          • 6792
                          • Bob
                          • Cardiff
                          #102
                          Hi Si, another excellent build I have not done justice. Looking superb!!
                          • Graeme C.
                            • 1604
                            • Graeme
                            • UK
                            #103
                            Very nice finish Si.:thumb2:
                            • Si Benson
                              • 3572
                              #104
                              Thanks chaps :smiling4:
                              Not quite finished just yet as I have cables to add and would like to see if any of the stowage I have will fit …
                              • scottie3158
                                • 14201
                                • Holbeach
                                #105
                                Si that's a great result mate.
