Ye olde Tamiya Jagdpanzer IV L/70
    Originally posted by Jakko
    Nice work, you’re clearly improving the kit a lot. The one thing I’m wondering about is why you don’t just take a more modern kit that’s more accurate already? :smiling3: Or perhaps you like the work you have to do here?
    That’s a good question. I need the practice!
      Thanks Rick - hopefully will turn out alright:smiling6:
        That’s a good reason to do it like this, IMHO. Get the skills back and then buy a kit that already has everything
          onwards….
          I was good to go for paint but decided to prime the fiddly tracks and do some more tweaking
          rear fenders positioned with retraction springs - ejector marks to fill in but pretty much done. I have lost two tow holes so they need to be scratched. Not too difficult really just a pain with the time needed.
          [ATTACH=CONFIG]n[/ATTACH]
          and the spade holders and bracket
          That will be it at least until the weekend. I want to do some interesting modulations and get a move on with the tracks and exhaust muffler. Some little bits will be done in the interim to add to w/end update.
            Originally posted by rtfoe
            Good to see the old Lang being updated
            Wabble
            Indeed, for auld Lang syne…
              Indeed it would be safer not have the shell bag fitted simply because it wasn’t. If I found any evidence at all you can rest assured that I would have weighed up my sources and fitted said item. As I am the author I get to call the shots on my build - which also means I bear any mistakes on my shoulders. That said I am always willing to listen to others or consider any contrary proposals as long as it’s not naysaying and it has at least some credibility even if it puts a spanner in the works.
                I have decided not to redo paint job. This has been a great experience in trying not to be random! In other words I didn’t want the paint scheme to seem contrived.
                I still have a fair bit to do.
                Wheels still need doing. Interior painting needs a little tweaking. Figures? Haven’t even started yet but they are going to be outside - although I do have an idea of what I want. Tracks - I can finish today
                So here I give you first version of the ’ Speckled Mandalsbrot‘ scheme
                [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
                • Si Benson
                  • 3572
                  #53
                  Superb job with the camo Paul, looks very neat anod tidy….are you using a paint mask system or free handing this scheme?
                  • The Smythe Meister
                    • Jan 2019
                    • 6248
                    #54
                    Yep, very nice indeed,looks great.
                    I did a similar scheme on a Hetzer earlier this year using a kit supplied mask.
                    It's a very eye catching look imho :thumb2:
                      Thank you Si. Afterwards I thought of using some stencil because my brush had an annoying out of place hair that was messing with my intended finish but I left it as is - all freehand. sometimes there can be a proclivity for over correction
                        Thanks Andy. Yes indeed - this was the scheme that I decided on some time back at the early stages of the build. It seems to be in the ‘family’ of ambush schemes.
                          Will need to rest up and reorg! The next steps need to be carefully planned whilst at the same time I will try to use the process to gain invaluable experience without messing up.
                          I plan on finishing the kit only and then providing the setting with a small narrative - There is something subtle yet radical that I want to try.
                          Then I want to store the kit and crack on with other builds. At some time all being reasonably well I want to move into diorama and figure painting. And then I have further uncharted territory in which I want to travel.
                            I meant ‘Thank you Rick’ :thumb2:
                            • Scratchbuilder
                              • Jul 2022
                              • 2689
                              #59
                              That paintwork is to be envied, well done, and on the build itself.
                                • 15686
                                Great paint job.
