IDF M109 'Doher'
  • Scratchbuilder
    • Jul 2022
    • 2689
    IDF M109 'Doher'
    As the Warrior enters its final stages, the next item on my build list is the IDF M109 'Doher'.
    I was going to base it on the Kinetic kit that I had just added to the stash BUT, after trying to get the twisted lower hull square in hot water, I gave it the elbow and plumped for the AFV Club M109. Later on I will return to the Kinetic one and revert this to either a British version or an American....
    So.... out came the kit, the reference and the extras....
    The extras include Black Dog resin interior, Voyager etch and AFV Club 'workable' tracks...
    So the first job was to assemble the lower hull...
    This consists of seven parts and needs to be square. I started with the rear panel and the floor, these were squared up on a sheet of thick glass rescued from someones discarded video/dvd recorder cupboard, Then came the sides, tops to the track sponsons and finally the sides and front of the hull.
    As I am adding the interior I decided that all of the ejector pin marks and the holes that you have to drill out would all be filled, this prevents the rivet counters from their "Ooooohhhh!!! let's count the ejector pin holes (sniff)" factor...
    First job was to add the floor and here because the hull sides are at a slight angle the floor has to be slid in from the front to the rear and then the front of the floor slightly bent to clear the final drive housing...
    ... As seen here, I also used the spare center torsion block to support the front of the floor. I decided to fit part of the drivers compartment which would then give me a reference for the other bulkheads to fit.
    Now that beautiful clean bench that you saw earlier - well now they look like this....
    The pliers are there to hold the resin blocks when sawing...
    More later
    Mike.
  • Andy T
    • Apr 2021
    • 3239
    Off to a flying start Mike!
    I'll get settled in before the rabble arrives.
    • scottie3158
      • 14197
      • Holbeach
      Mike,
      Chair pulled up to watch the magic happen.
      • rtfoe
        • 9065
        Hi Wibble, looks like a good start. Always fancied an M109 in IDF livery. I've just rolled my chair into front row for this next to Andy.
        Wabble
        • Richard48
          • 1889
          • Richard
          • Clacton on Sea
          Nice start Wibble.
          I think i have a Doher conversion i picked up from an Ipms show in U.K for next to nothing.I believe it has the MGs missing.If i can find it would you like to have it for your builds.
          RIchard
            • 15645
            I'll take one of the last front row seats please. Great to watch this build.
            • Si Benson
              • 3572
              Not seen a Doher before so will watch with interest :nerd:
              Initially I thought doher was another name for a D9 dozer….which I would like to add to the stash.
              I’ll keep an eye on the rabble and chuck some sausage rolls about if they get feisty :thumb2:
              • Scratchbuilder
                • Jul 2022
                • 2689
                Andy, Scottie, Wabble and Jim R,
                Welcome to the build, I must get away from adding the interiors to the builds.
                Mike.
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  Si,
                  Welcome, I will try to keep you entertained.
                  Doobi was the name given to the D9, I think the translation is teddy bear.
                  I do believe Meng produce one complete with the bar armour which would save on the work of adding the brass offering.
                  Mike.
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    Richard that is a very kind offer and it would be well recieved.
                    Wibble.
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      As I can't do nufink myself. I've polished my lens on my specs and fuelled up the magic carpet Mk7 and as 'Mike the master' does a damn fine bit of armour, I'll hang around. :thumb2:
                      • Scratchbuilder
                        • Jul 2022
                        • 2689
                        Doug. Many thanks for the compliment, let's hope it all comes out ok.
                        Mike.
                        • rtfoe
                          • 9065
                          Mike.
                          Minus the interior Wibble and the tally of parts will still hover around 750 give or take 50 more pieces. :smiling6: ...okay somebody chuck me a sausage roll...luv em.
                          Wabble
                          • Mini Me
                            • Jun 2018
                            • 10711
                            What a beast!.......nice choice, should keep you busy for awhile. :thumb2:
                              • 22769
                              Nice subject, and a very nice start Michael. Just pulled up my chair.
