IDF M109 'Doher'
    Same, and I never manage to bend them into shape correctly anyway, being so tiny. Bent copper wire I can do, though, or a couple of punched discs plus a bit of thin rod or stretched sprue. Iโ€™ve been meaning to make a jig like the one Mike mentioned above (and has before) but as per usual, I never remember to when Iโ€™m in my modelling room
      • 15704
      That foam putty stuff looks to have worked well. Unlike plaster based products I suppose there is no shrinkage or cracking. Will it need sealing before paint?
      • JR
        • May 2015
        • 18273
        #153
        Excuse me Wibble .
        Jim I've used their foam putty , it's really good. Seals XPS foam .Used it on a dio and just varnished the surface .Dries very hard.Strange as it's so light.
        • Scratchbuilder
          • Jul 2022
          • 2689
          #154
          The blurb on the tub says you can paint over it, but being the coward that I am I will put a coat of acrylic over it as a base, and then a test on a piece to see how it reacts to lacquers.
          • Scratchbuilder
            • Jul 2022
            • 2689
            #155
            Originally posted by JR
            Excuse me Wibble .
            I tried eating it, well I was hungry and it really looks like Angel Delight, that and the Prunes went down a treat - no reaction so far....
            • boatman
              • Nov 2018
              • 14479
              • christopher
              • NORFOLK UK
              #156
              :thinking:Mike you are the crazeist member on here well done on given us a good laugh :rolling: :tongue-out3: :smiling: :smiling: :smiling:
              chrisb
              • Miko
                • Feb 2024
                • 582
                #157
                Ha! I laughed so hard it hurt a bit!
                Miko (impressed by the snowy dio!)
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  #158
                  chrisb
                  I thank you...
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #159
                    This is how the Aber large tie downs look after being in the stamp machine....
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      #160
                      Update,
                      So had a serious play with the water trap bucket and spray booth and must say all went better than expected, no fume or nasty smells - except for one thing - after I had finished priming and cleaning up, throwing the used kitchen towel into the recycle bin I could smell the fumes from the thinner and laquer.... What I had forgotten to do was after spraying one item I should have moved it to the shed to dry and not leave it in the room (idiot).... But I did what I should have done when putting the top coat on and no smells at all...
                      The Yellow items are the fire extinguishers in undercoat - red on tomorrow...
                      The tie downs are all done...
                      The base has had a coat of pva on the white 'floor' and the outer bank and sides are covered in wood sealer...
                      Once I start to add the 'earth' mixture then the whole sides and floor will be blended in together....
                      And that is it for now.
                      Mike.
                      • minitnkr
                        Charter Rabble member
                        • 7541
                        • Dayton, OH USA
                        #161
                        Look'in good.
                        • JR
                          • May 2015
                          • 18273
                          #162
                          Great work Wibble.
                          • Scratchbuilder
                            • Jul 2022
                            • 2689
                            #163
                            Great work Wibble.
                            Thankyou...
                            • Scratchbuilder
                              • Jul 2022
                              • 2689
                              #164
                              Originally posted by minitnkr
                              Look'in good.
                              Paul Thankyou.
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #165
                                Update,
                                More work on the turret interior...
                                And the hull has finally got the fire extinguishers in place...
                                Now just a couple of ratchet straps to add and the lid can go on and then I can start to build the kit...
