Carrier conversions 28mm
  • scottie3158
    • 14201
    • Holbeach
    #16
    Chris, some great details being added, even better when you realise how small these are.
    • Steve-the-Duck
      • Jul 2020
      • 1731
      • Chris
      • Medway Towns
      #17
      Many thanks. I need my on stand magnifier permanently on hand
      Copious use of 10 and 20 thou plasticard, plus random strip bits go into these!
      Forgot to mention, the back plate behind the driver had some surgery done, to turn the seat rest the other way up as it's at the top
      The top edge of the side panels may get sum greeblies added, as cover tie-downs. Unfortunately the phot reference show the tilt attached, so I don't know what's there. Even the plans are vague
      • adt70hk
        • Sep 2019
        • 10402
        #18
        Some great conversion work going on. Really very impressive.
        Keep up the good work!
        • Steve-the-Duck
          • Jul 2020
          • 1731
          • Chris
          • Medway Towns
          #19
          So, the Light Dragon Mk.III is pretty much finished. I will probably do a tilt cover one painted, with the sides up
ID:	1216726Click image for larger version
ID:	1216727Click image for larger version
ID:	1216728Click image for larger version
ID:	1216729Click image for larger version
ID:	1216730Click image for larger version
          The commander figure will be fixed in once everything else is painted. I've used the Milicast 1/76 casting as reference for the rear as still the only phot of the back has an 18/25 pdr and limber being towed, in the way.
          All kit parts and figures still Warlord
          I had completed the tilt frame, but I thought it looked too tall. Then I found the maker's drawings I've got in the 'Moving the Guns' book have actual dimensions. That, and the photo show the commander head-an-shoulders above the tilt
          Cue me removing the brass, cutting the the down, and lowering the tops of the sides by a millimeter. It looks better now, I think. But I could still cock-up the paint job!
          Time to complete the Cavalry carrier now
          • Steve-the-Duck
            • Jul 2020
            • 1731
            • Chris
            • Medway Towns
            #20
            So, here we are, the Cavalry carrier is built
            Rifle frames and body work added, plus the seat back frames
            And so...
ID:	1216945Click image for larger version
ID:	1216946Click image for larger version
ID:	1216947Click image for larger version
            The pyramid frame at the front is for the tilt cover. Strangely, this was the only variant of the carriers with a tilt cover frame included from the start
            Side skirts are from an old MiG-21 fuel pod cut down. I couldn't cut the aluminium tube easily enough, so just a bit of scraping and shaping
            The crew are going to require some major surgery, so I may do some undecoating of all three first before THAT exercise
            Still tempted to do a Mk.I, as the mesh side-skirts do look better
            • Peter Gillson
              • 2594
              #21
              Excellent work - lookkng really good.
              Peter
              • scottie3158
                • 14201
                • Holbeach
                #22
                Cracking work.
                • Richard48
                  • 1892
                  • Richard
                  • Clacton on Sea
                  #23
                  I agree with Peter and others.Lovely wee carriers.
                  • Steve-the-Duck
                    • Jul 2020
                    • 1731
                    • Chris
                    • Medway Towns
                    #24
                    Halfords matt black spray as undercoat. It's VERY matt!Click image for larger version
ID:	1217121Click image for larger version
                    I've already done the all-over spray of Olive Drab, which is fairly close to the G3 Khaki Green base colour
                    Now, I just need to re-drill the aerial mounting on the Scout!
                    • Steve-the-Duck
                      • Jul 2020
                      • 1731
                      • Chris
                      • Medway Towns
                      #25
                      So, block painting is done, next for shading, marking and weathering. Now to work on the Cavalry carrier crew, and the Dragon tilt
                      Base colour, for G3 analogue, is Humbrol Olive Drab spray, then two different greens for G4 a-likes. My G5 analogue doesn't contrast very well with the olive drab, so I usually use that with a dark green or more brown base
                      • Steve-the-Duck
                        • Jul 2020
                        • 1731
                        • Chris
                        • Medway Towns
                        #26
                        So, an all-over brown ink wash to shade, next for the detail painting
                        • Steve-the-Duck
                          • Jul 2020
                          • 1731
                          • Chris
                          • Medway Towns
                          #27
                          Paintwork and markings on with basic weathering. Starmer mostly for the AoS and divisional signs and census numbers
ID:	1217722Click image for larger version
                          Just a few details on the Scout, crew for the Cavalry and the tilt for the Dragon left, then they'll get the all-over matt spray. That should also tone down the transfers a little
                            Very nice group of early Carriers
                            • Steve-the-Duck
                              • Jul 2020
                              • 1731
                              • Chris
                              • Medway Towns
                              #29
                              We rapidly approach a conclusion
                              The crew for the Cavalry carrier are complete
ID:	1217818Click image for larger version
ID:	1217819Click image for larger version
                              As can be seen, they wouldn't fit with the seat back in position, that only left room for two figures.
                              Easy solution, take that off and make a new one attached to the figures themselves. Also, needed to take some off their feet for them to fit in the narrow gap
                              The near-side right-hand foremost has no right arm, as yet, as he's going to be leaning on the panel behind the driver. The corporal is guiding the way from the back-seat!
                              • Steve-the-Duck
                                • Jul 2020
                                • 1731
                                • Chris
                                • Medway Towns
                                #30
                                The tilt cover for the Dragon is made from Apoxie two-part putty, recommended to me by my brother-in-law. Although he does say it's a little toxic, so more caution needed than Miliput. It's damn good stuff though
                                This is the underside inside, so it's a bit scrappy with extra filler
                                Next is cleaning and painting!
