Scotties Tamyia Centaur.
[ATTACH]496626[/ATTACH]
[ATTACH]496627[/ATTACH]
Inserting plugs and switching on lamps is because these connect to leads going to electrical detonators, that will set off lengths of Cordtex (detonating cord) behind the waterproof fabrics over various openings. Stages 5 and 6 are clearly intended to be done when the action has died down, so if you add ducts to a model, everything that is only removed in those stages would still need to be present as well. That quickly turns into a lot of work, though.Comment
Oh no! not another of these got to replace everything including the kitchen sink builds.... Notice the front rank scroungers were first on the scene grabbing all the biscuits and leaving the broken ones for the rest of us - you know who your are Si and Jim....
Looking good Paul, another one of your masterpieces by the look of it.
MikeComment
Mike
Rick, lots of seats left, but the Hob Nobs are running out quick.Comment
Not a lot of time at the bench lately but things are progressing slowly. I won't bore you with descriptions as the PE is self evident. The only things apart from that is the new crow bar, the shovel has been thinned down and the front side lights have been scratched along with their cables. The only other additions are the headlight guards Have been made from wire. I only made these as two from kit were missing.
Oh and one bin lid was replaced to give it a bit of a dent.
cheers
ScottieComment
