Scotties Airfix M3A1 Scout car.
It's been a while since I did an update. both doors are now finished with internal and external details added from pewter, copper wire and plastic. I still have to make and add the hinges. The windscreen is under construction so please ignore the bits sticking out. The bumpers have been made from thin brass sheet.
a bit of clean up around the detail is required.
the rear luggage rack is also now fitted.
I am going tp probably put this to one side now for a while and start something else as I am loosing a bit of interest in this now It turned out to be a lot more work than I envisaged. Or I might just do a bit here and there.
cheers
ScottieComment
It will be a crime to paint this one, you have put so much work into it, it has got to be shown.... Plain black base will show it of even more.Comment
Cheers Mark, it wasn't my intention when i started lol.
Your right John it has been a hard build but it has pushed my skills and although I was getting fed up with it, it is also satisfying every time another step is finished.Comment
I'm not sure if you have anything that makes you more susceptible Paul, but cramp (in layman's terms) is quite often as simple as dehydration. If you find drinking more water doesn't help, electrolytes could well be the answer.
The build however, is beyond my words.Comment
True, very true, wet fingers in the plug socket gets your attention every time and straightens your hair..... electrolite works every time, or is that electricity....Comment
Cheers Jack, touch wood I have been fine since so yes you could be right it might have been a simple bit of dehydration. Glad you like the build so far.Comment
I am beginning to seriously wonder about the sanity of this group lol.Comment
