Wow Scottie
Scotties Airfix M3A1 Scout car.
Thank you John that is very kind of you.
Thanks Mick.
:smiling: :smiling: :smiling:Comment
Just to give the eyesight a rest and let the black base coat dry nice and hard. I though I would make a start on the base. I decided to recycle an old building and add it to a new base. The plan is to show an old goods yard. The main parts are roughed out. and nothing is stuck down yet. The rail track looks a bit proud at the moment as again its not stuck down. Any suggestions as to what to add Will be great fully received.
There will be a hand rail around the edge when I work out how to make it.
cheers
ScottieComment
I like the sound of that. The iron pipe fence was what I had in mind.Comment
I have started to add detail to the basic sections. Some exposed brickwork on the platform and cracking of the concrete. I have fashioned a pipe fence which looks wonky as it's not secured to the base. I have tried to show a couple of damaged posts with a bit of the rebar showing. Also started to populate the scene this is just for an idea. I made a very crude wooden crate and covered it with a tarp made from greenstuff.
any suggestions or advise will be great fully received.
cheers
ScottieComment
Freakin' WOW Bro!!!! I'll write more later after I calm down, Paul...
AllenLife's to short to be a sheep...Comment
