Scotties Airfix M3A1 Scout car.
  • Mini Me
    • Jun 2018
    • 10711
    #91
    The actual diameter of the rivet head differs from its bore diameter, usually two times the diameter of the bore. Example, if you have a 1/4 inch dia. rivet...the exposed head will be 1/2 inch in dia. They really show up well in photos. Yours look fine Scottie....even if just a tad over scale, they will blend in beautifully and virtually disappear once you get the CITB....as to the exterior, all the better to see them once painted weathered and judiciously muddied up! Where's "Rivet Jones" when you need him??? :tears-of-joy::tears-of-joy::thumb2:
      not sure what reinforcing plate you mean is it the one that runs vertically from the centre of the box if it I still have to add it.
      That one, yes. It’s actually behind the box, the two vertical lines of rivets you can see running up from the centre of the wheel arch are what hold it to the side plates.
      • scottie3158
        • 14201
        • Holbeach
        #93
        Yes that has still to be fitted as are other details. Thank s for keeping me on my toes I may have missed it.
          Have you got (and/or any interest in? ) Steve Zaloga’s article in an old Military Modelling, in which he basically does what you are doing here too, namely replacing the whole rear body of this kit by plastic card?
          • Allen Dewire
            • 4741
            • Allen
            • Bamberg
            #95
            Using 0.6mm punched rivets I have come up with this.
            [ATTACH=CONFIG]n1217465[/ATTACH]
            Next to make and fit the tie downs before detailing the inside.
            cheers
            Scottie
            Great stuff Bro!!! I've been following from the cheap seats and loving every minute of it. Those springs were incredible and now this. At the rate you're going, you'll put Rosie the Riveter out of a job Buddy!!! Do you ever have a prob with them falling off while handling the parts? Just wondering...
            Allen
            • scottie3158
              • 14201
              • Holbeach
              #96
              Have you got (and/or any interest in? :smiling3: ) Steve Zaloga’s article in an old Military Modelling, in which he basically does what you are doing here too, namely replacing the whole rear body of this kit by plastic card?
              Yes mate it will good to see how a good modeller went about it.
              • scottie3158
                • 14201
                • Holbeach
                #97
                Allen
                Thank you mate it's always good to have you looking in. They do come off sometimes but normally I am lucky. I have some Quinta rivets on order to see how I get on with them and see how they look.
                  I’ll see about finding the back issue and scanning it, then.
                  • scottie3158
                    • 14201
                    • Holbeach
                    #99
                    Jakko that would be good of you but please don't put yourself out.
                      OK, in that case I’ll just link to a short version
                      • scottie3158
                        • 14201
                        • Holbeach
                        #101
                        Thanks mate.
                          • 15670
                          A lot of very neat work Scottie. Really looks good. As to whether the the size of the rivets look ok it is difficult to judge until the whole side is tied together with a coat of primer.
                          • scottie3158
                            • 14201
                            • Holbeach
                            #103
                            Cheers Jim, I have tried out some Quinta rivets on the other panel. And I am quite impressed they take a bit of getting used to but I think they look a lot better I will post a comparison picture tomorrow. Trouble is it does mean I have to redo the other side.
                            • Neil Merryweather
                              • Dec 2018
                              • 5184
                              • London
                              #104
                              really? is anyone going to see both sides at the same time....?
                              • scottie3158
                                • 14201
                                • Holbeach
                                #105
                                Neil, very true but I would know plus it doesn't take that long.
