Junk.
[ATTACH]506798[/ATTACH]
That’s a good word to describe Stynylrez primer, IMHO. The text on the bottle says to use it unthinned and spray thin layers until the underlying colour disappears, so I did. With the result you can see in the photo. This is the third time I’ve tried using it, and the first time on a whole model — well, two, actually, because I also sprayed the metal parts on the Sherman I was given at the same time. To get this fine result took me three quarters of an hour, and it still doesn’t cover properly, but I gave up because my airbrush (Aztek with a light blue nozzle) did due to being clogged so badly I had a devil of a time getting it to even spray airbrush cleaner.
For comparison:
[ATTACH]506799[/ATTACH]
This is the turret of the Sherman, after about ten seconds’ worth of spraying Vallejo white primer from an aerosol can (plus ten more on the other side), which I did because I want a white line on the turret but didn’t think I’d get there easily with the Stynylrez.
As a primer, if you ask me, Stynylrez lives up to the name on the bottle: crap.
For comparison:
