Tamiya M4A3E8 - Korean War
  • NickInTheValley
    • Feb 2024
    • 24
    Starting the build on Tamiya’s kit 35359 of a Korean War M4A3E8. In my intro post I mentioned gave up on an old Dragon kit for now. This kit already is a welcome respite from those headaches.
  • Miko
    • Feb 2024
    • 582
    Looking forward to seeing your inaugural build, that front paint job looks interesting!
    Miko (often considered building the Oddball's Sherman from 'Kelly's Heroes')
    • NickInTheValley
      • Feb 2024
      • 24
      I'm not decided yet on if I will paint that specific Sherman or if I'll do another Korean war tank. Still thinking it over.
        That’s quite a good kit, IMHO. Like I mentioned before, fit of the bogies is a little loose so you may want to take care getting them to sit right, but otherwise it’s a typical Tamiya kit I also mentioned the tracks were not great, but as you have the Korea version, it has different tracks to the Second World War variant I built, so ignore that part — I don’t know anything about the tracks in this one.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4596
          • Bob
          • London
          In for the build.
          Si vis pacem, para bellum.
            • 22769
            Nice one Nick.
            • NickInTheValley
              • Feb 2024
              • 24
              Standard construction at this point. Not too many areas to address to my novice eye. Going together nicely!
              • scottie3158
                • 14197
                • Holbeach
                Chair pulled up I will follow along in the cheap seats.
                  It’ll be easier to build than the 105 mm M102 howitzer you also have, and if it all goes horribly wrong anyway, it looks like you’ve got a good way to dispose of the model at hand too
                  • Airborne01
                    • Mar 2021
                    • 3939
                    • Steve
                    • Essex
                    Love the paperweight!
                    • NickInTheValley
                      • Feb 2024
                      • 24
                      That Howitzer is a pain but it's primed. Only problem I have now is I lost one piece that the barrel assembly mounts to the trailer/frame. I need two.. I'm missing one. If I can't find it I will have to make something.
                      Yeah the training grenade can smash it.
                      • JR
                        • May 2015
                        • 18273
                        I shall follow please.
                          I built it 20 years ago or so, when it was fairly new, and remember I didn’t find it that easy to assemble, no. Which just makes it pretty typical AFV Club kit, I’d say I somehow managed to lose one of the four springs … But since they’re a single spring each side anyway, I just wound copper wire around both equilibrators instead.
                          Which parts do you mean?
                          What, it’s not live? And here I was, thinking you were in the USA!
                          • NickInTheValley
                            • Feb 2024
                            • 24
                            The companion to this:
                              I looked at the instructions before I asked, and I was kind of hoping you didn’t mean that bit I’m sure it can be scratchbuilt, but it won’t be easy to get it to look like that. Maybe go for a simpler block shape without the ribs in it? Then throw a crewman’s jacket over it or something
