I'll have to get one Paul thx for the heads up
Brian's Centurion Mk5
The lifting handles are much easier to clean up if you glue them in place first, and once the glue has dried, slice off the remains of the attachment point with a sharp blade. The sharp part is important, donโt use one that has gotten fairly dull with use.Comment
Where the tracks join together it is normal practice to staple the join and then hide it under the 'bazooka' plates that way the join cannot be seen. If you are going to use the AFV Club workable tracks then they are a click/press fit, but can be a bit frustrating at times. They join together like the three links on the front glacis plate.Comment
