Also, have tamiya changed their plastic? about a dozen attempts before i got two decent pieces ... It used to be the best for stretching to make antenna and rigging ... or is the fact i may be turning into a bumbling retard the problem? answers on a postcard please
this there chieftain is looking treeemendouuus m8,i need to learn how to put lights in as i`m gearing up to do the Illustrious and want to put lighting in it and on it.also where abouts in this bonnie land do you hale from?
The lights were just cheap (poundshop) xmas tree lights, i bought a load in red blue and clear for future projects when they had a sale (50p per set of twenty)
It's just basically drill a hole and trail the cable back to the little battery box ...
I'm in Loanhead, just south of Edinburgh ... when i go sea fishing i'm north-west side of Inchkeith so i could shout over to you ... you're in Burntisland aren't you?
I like that a lot Colin. Nice wash & the dust & mud looks very good. What do you make your mud mix from?
If you've brush painted the whole thing, you've got a remarkably smooth finish.
The led is class, I'd like to see more touches like that.
As for the plastic, don't forget it's an old kit, but didn't Tamiya used to leave one particular section of sprue specifically for stretching? Something to do with inhaling toxic fumes if regular sprue was used?
Could just be my poor memory, too much sprue stretching!
Thanks Patrick, the mud is just a Bi-carb and paint mix ... I use the standard method ... paint where you need the mud, sprinkle bi-carb and then after it's dried out just add some thinner solutions of varying colours.
I use Citadel acrylics and a decent quality artists acrylic water colour for tonal changes, i always use natural hair brushes as i myself feel i have more control of the paint ... spent years painting in waters and oils on canvass to relax.
I saw Johns signature and thought i'd nick the idea (don't tell him), I might see if this is possible on most of my future models.
As for the plastic, don't forget it's an old kit, but didn't Tamiya used to leave one particular section of sprue specifically for stretching? Something to do with inhaling toxic fumes if regular sprue was used?Could just be my poor memory, too much sprue stretching!
This i didn't know, when i go in my little cupboard under the stairs and find this aforesaid section then it'll confirm my bumbling retard comment heh heh
It's on the sprue containing the wheels, in a corner marked with a tab with 'PS' on it......Ron
Right, bumbling retard i am ... found the sprue section but there's nowhere in the documantation that says thats what it's for .... well none that i can find anyway .... if there is some then i'm going to crawl into a corner sobbing
Ha, got ya!
In the corner you go Colin.......
It's on a separate piece of paper stating, amongst other things, the PS stands for polystyrene.
Don't sob too much mind, you might get some funny looks and not very complimentary suggestions!!
