Scotties Bergpanzer Buffalo.
Yes mate far to modern for me but a change is as good as a rest as they say.
Doug, of you got me lol.
Ha ha ha thanks Neil.
:thumb2: :thumb2: :thumb2:Comment
Hi Ron there are a couple of methods I use. the one in the picture which I have redone since the picture is two part putty. Rolled out into a very very thin sausage this is then formed around the item where you want the weld. I normally stick in place with a bit of CA. Let the glue dry and for the putty to go off a little then with the point of a scalpel blade impress the detail. The other way is to use stretched sprue glue in place when dry apply liquid cement to soften the sprue and then again press in the detail with a scalpel blade. HTH.
There certainly is.
No just a little indistinct.
Made a start on the interior. I am not going to go overboard with the detail as not much will be seen when all buttoned up. So just add a little that will be seen if you look in the hatches.
The drivers seat had some bolt detail added and the seat adjuster.
There is also a lever to the left hand side of the seat that as far as I can see disappeared under the floor plate and was used to raise or lower the seat arm. If anyone does know please let me know.
Next the commanders foot rest was tweaked.
Before
After
it still needs a little cleaning up.
cheers
ScottieComment
Wow, that is a lot of drilling out … I hope for your fingers you didn’t do that with a pin viceComment
The rear panel has had a bit of detail added, mostly to the towing pintle, including levers, bolt detail, strap and chains. The towing eyes have been drilled out with pins and clips added with weld detail added. Please bear in mind they still need a bit of cleaning up. The convoy shield which is typical of German vehicles has also been added, it has a lamp holder which I will add when I have painted the white cross..
I have decided to build this without the extra armour as so much detail will be lost to view, I would like to show it with the side access hatches open and the stores locker. But I might change my mind late lol.
cheers
ScottieComment
