AEC Armoured Regal Bus - 1/72 - Fylde Armouries
  • vizenz
    • Apr 2024
    • 426
    Hello,
    This is at the moment the second project that made it to my workbench. Another Brit... It seems like I'm having something of a "British phase" :smiling5:
    The model is self printed with a 3D printer. The files come from "Fylde Armories" and are actually in 1/56.
    I adjusted the scale to 1/72 and added some details. As far as I know, there are only two photos of this bus, which is why everything can only be adjusted by eye. The entire actual model building and converting took place on the computer (adjusting the radiator grille, adding some details and many rivets).
    The printing itself worked. There are still a few parts that I don't like that much. The next few days will show whether I can use the first print or whether I have to do it again. Either way, I won't spare you with progress.
ID:	1222670Click image for larger version
ID:	1222671Click image for larger version
ID:	1222672Click image for larger version
ID:	1222673Click image for larger version
    Best regards,
    Andi
  • Scratchbuilder
    • Jul 2022
    • 2689
    I have seen this built up and it makes up into a good representation of the vehicle.
    • vizenz
      • Apr 2024
      • 426
      I hope so! :smiling5:
      I had already worked on the few parts that I didn't like so much (like the radiator grille that was too wide) in advance.
      Unfortunately, this radiator grill in particular was printed poorly (my mistake, incorrectly placed supports).
      Since it's not exactly fun to cut and sand resin, I put off this work for quite a while. But today I finally had the courage to put this misshapen bus back on the workbench. I sanded down every possible spot, replaced the radiator grille, installed the tires and filled, sanded and cleaned everything. Now the fun part can finally begin!
      I hope I find the time to pour some paint on it tomorrow.
        That is very much an improvement, you certainly didn’t waste the effort to correct it.
        • vizenz
          • Apr 2024
          • 426
          Hello,
          Yesterday I actually had some time to start painting.
          After priming with Black AK Primer, a coat of Khaki Green No.3 from AK Real Colors followed. To make all the large areas a little more interesting, I lightened the base color with a few drops of ivory and tried a color modulation.
          One can certainly argue about what colors these improvised vehicles actually were. Certainly not only military colors were used. After some consideration, I still went with G3/Dark Tarmac, simply because that's how I interpreted it from the photos and because there's some probability that it was used.
          What you can't tell from the photos is that I then tried to paint the camouflage stripes like in the original photos of the bus. Unfortunately, the angle from which the vehicle was photographed makes the whole thing really difficult. Now it was also clear that some of the reference points in the photos did not correspond to the positions on the model... In short, I completely failed! After a few tries, I completely decolorized one side of the model with isopropanol and am starting again today!
          • vizenz
            • Apr 2024
            • 426
            OK done!
            Although it may not look like it, this was by far the most difficult camouflage paint job I have ever done on a vehicle. The slanted perspective of the photos is incredibly difficult to transfer to the model.
            I printed out the photos at 1:72 scale and greatly enlarged another set. I then divided the areas into grid squares and tried to transfer the camouflage pattern onto the model with a pencil. That worked somewhat. It looks very confusing and "psychodelic", but it's pretty close to the camouflage pattern in the photos.
            • scottie3158
              • 14198
              • Holbeach
              That looks superb mate.
                I think what I would have tried is to remove the perspective from the photos, and then size them so the sides are the same dimensions as the model. I can only find one picture online on a quick search, and it’s very small, but basically like this:
                [ATTACH]508215[/ATTACH]
                That’s Photoshop’s perspective crop tool in use. After cropping, that results in:
                [ATTACH]508214[/ATTACH]
                This is, of course, far too short, but just making the image wider solves that:
                [ATTACH]508216[/ATTACH]
                Note that this isn’t accurate, because I don’t know how long the real vehicle is, but it gives a good impression of how you could do this with a bit more care and better photos
                • spanner570
                  • 15379
                  ...a bit more care or not, your paintwork is looking great. Clever stuff!
                  Well done Andreas. :thumb2:
                  • Steve-the-Duck
                    • Jul 2020
                    • 1731
                    • Chris
                    • Medway Towns
                    It's funny that this is the ugly, improvised, cousin to the 0853 ACV 'Dorchester'
                    More Brit improv and stop gap armour, please, Andreas!
                    • vizenz
                      • Apr 2024
                      • 426
                      Thank you for the menthal support Paul!
                      Originally posted by Jakko
                      I think what I would have tried is to remove the perspective from the photos, and then size them so the sides are the same dimensions as the model. I can only find one picture online on a quick search, and it’s very small, but basically like this...
                      Jakko, I just wanted to try this out to prove to you that it doesn't work anyway.
                      I digitally painted a few things onto the 3D model, took a screenshot in a completely crooked perspective and - the program did a great conversion! In the end it looked 98% as it should. Next test - same result! Wow! Learned something again. I could have saved myself all the work and a lot of frustration with just a minute of perspective calculation from a drawing program!
                      I can only recommend it to anyone reading here who has similar problems.
                      Very good tip, thank you very much! :thumb2:
                      To safe my honour, I have to say that my approach was a bit old-school, but it worked quite well. Here too, the agreement with the pattern calculated by the program is quite high. Mainly my "tips" are a little sharper, the calculated transitions are a little softer. But out of sheer laziness and/or stubbornness, I'll leave it like that now! :tears-of-joy:
                      Thank you Ron.
                      That was exactly my first thought! Looks like a "Dorchester" painted by a three year old child! :smiling5:
                      And your wish is my command. More British Oddities are already being planned.
                      • JR
                        • May 2015
                        • 18273
                        The Committee headed by Matron took one look and with an unanimous vote have given you
                        Congratulations Andreas:thumb2:
                        • Lee Drennen
                          • 7711
                          [ATTACH]508258[/ATTACH]
                          Wow another one. This is getting out of hand. The Committee must be very impressed with your builds Andrea which says a lot only the few get these award’s. Great work and hard work is paying off.
                            To be honest, I was wondering myself if it would work over as large an area as this. My fear was that things like the panel lines would end up ever closer together when they were spaced evenly on the real thing. That is fixable by using more complex perspective warp, but it looks like the simpler perspective crop works well enough without that after all
                            Thanks
                            • Mickc1440
                              • 4775
                              Excellent work on that paint job
