1/35 scale Centurion Mk.12
  • Scratchbuilder
    • Jul 2022
    • 2689
    #151
    Update,
    Gone is the nice shiney green and black, next it is the toned down version.
    The turret with the camoflague net fixed in place.
    And now the weathering starts.
    All of the major parts (hull,turret, 'bazooka' plates and wheels) were given a wash of Flory Models 'Grime' wash. This was left for about 15 minutes and then a dampened flat brush was used to remove most of the 'Grime'. I then went back over the hull, turret and bazooka plates with a 'fan' paintbrush that had first been dipped into clean water and then the excess wiped on a folded piece of kitchen towel. The brush was then lightly used in a downward motion where the clean water on the bristles cleaned off the grime some more but left streaks that same as you would get from rain running vertically down a verticle or sloping surface.
    This has been allowed to dry for 24 hours, and during that time I painted the tracks ready for fitting.
    Next will be adding the rust texture to the exhaust system and to the blades and 'ski's' on the plough, then will come a fine dusting of dirt to try and match the photograph of the real vehicle.
    More later
    Mike.
    • Andy T
      • Apr 2021
      • 3239
      #152
      This is looking superb already Mike!
      And so the few acrylic paints I had are now residing in the bin, I am free..... From now on it is back to enamels, lacquers and oils....
      Will they cover any brush painting that's needed? I've only really used acrylic for that, perhaps I should branch out.
      • Scratchbuilder
        • Jul 2022
        • 2689
        #153
        Sorry Andy a bit thick today so bear with me.
        If it is the wash from Flory, it will cover all paint versions except you need to have a matt or satin base to work with, with gloss and with the wash being water based it just runs off the model. I usually have a matt varnish applied over the paint or use matt paints. For spraying matt varnish I use AK Ultra Matte Varnish, it looks terrible when it goes on but dries flat and as you can see is totally matt.
        As for enamels/lacquers, they will cover acrylics.
        • Andy T
          • Apr 2021
          • 3239
          #154
          I confused things by using the word "cover" I think, sorry! "be suitable for" would probably make more sense.
          I mean, since you have now ditched all of your acrylics, will you be able to carry out any brush painting that is needed with your remaining media?
          • Si Benson
            • 3572
            #155
            The flat coat has worked well Mike, looks ace
            • Scratchbuilder
              • Jul 2022
              • 2689
              #156
              Confusion cleared.
              Yes you can still brush paint, and with the AK, Tamiya etc you can actually thin by about 25% or to airbrush get a new pot of the colour you want to airbrush and fill to just below the rim and that is sufficient to airbrush.
              Oils will come in for blending and adding the streaks plus there is a selection of colours that simulate rust, so fun can be had blending and thinning on the model.
              • Scratchbuilder
                • Jul 2022
                • 2689
                #157
                Thanks Si, when you first spray it on it looks like giant orange peel and if you are not used to the initial effect or have forgotten, the panic bells and alarms start going off. I had forgotten, and it was a case of stick with it or pick the whole lot up and dunk it in the sink :cold-sweat: but like the coward I am, I just left it in the shed and locked the door for a couple of hours....
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  #158
                  Update,
                  Weathering is underway - first on the menu is to give the vehicle a dusty appearance. This was achieved by first mixing VMS 02 Light Earth pigments into a pot and then adding ordinary water from the tap untill I had the consistency of thin ink. The hull took the first position as I could try out the opacity of the mix on the underside. Once this was to my satisfaction then the whole upper surface, front and rear were coated in the mix and set aside to dry. Next it was the tracks - but only the outer surface, as the mix would in places run through the sprocket holes to add some difference to the running surface of the tracks. Then it was add more water to the mix and give the wheels, Idler wheels and drive sprockets a thin coat. Finally came the 'Bazooka plates' and a thinner mix going over the turret...
                  All of this was left overnight.
                  Today I started removing most of the mix I had put on using clean tap water in a pot and using various brushes first dipped in the water and then the excess removed by touching the brush onto some folded kitchen roll. And I kept removing the mix untill I was happy with the end result. To add the streaks I used a fan brush stroking in a downward direction.
                  The tracks came in for a different approach. I have an old handkerchief (washed and unused) which I soaked in water and then it was rung out untill it was damp. This was then wiped over the rubber pads with the 'kerchief wrapped around a finger and with a couple of strokes from the centre outwards, removing the mix, followed by a wipe with a piece of tiolet roll (again unused) to soak up any excess water...
                  Right side is after, Left side is before removal of the mix...
                  Tracks before....
                  Tracks after...
                  Tracks fitted and Fascine carrier test fitted as I broke off the securing clamp during wheel fitting...
                  A dry fit of the turret and Fascine carrier...
                  Still more work on the weathering to do...
                  More later.
                  Many thanks for all the comments and likes.
                  Mike.
                  • scottie3158
                    • 14201
                    • Holbeach
                    #159
                    Mike,
                    Looking superb already.
                    • Andy T
                      • Apr 2021
                      • 3239
                      #160
                      Confusion cleared ~
                      Thanks Mike.
                      Love today's update, it's getting better & better.
                      • A_J_Rimmer
                        • May 2024
                        • 801
                        • Arnold
                        • North Wales
                        #161
                        That's a stunning build Mike, it's coming along very well. I really do like that camo netting.
                        Thanks for the description of how you dusted up the hull, that was really useful. Just to clarify, did you spray the water/pigment mix onto the model?
                        Arnold Judas Rimmer BSc SSc
                        ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
                        • Scratchbuilder
                          • Jul 2022
                          • 2689
                          #162
                          Thanks for the comment Arnold.
                          I used a #4 soft brush or in technical terms a medium soft brush. and brushed on an area at a time, there is no need to rush because you can leave the mix to set for a few hours and come back to it. You just need to brush the mix on and move it around so it covers the area.
                          • Scratchbuilder
                            • Jul 2022
                            • 2689
                            #163
                            Just a bit more done....
                            Exhausts have been weathered, bazooka plates added along with the exercise panel (still to be weathered) and the fascine carrier now in place.
                            Next will be weathering the plough blades and 'ski's'.
                            Mike.
                            • scottie3158
                              • 14201
                              • Holbeach
                              #164
                              Love it mate.
                              • A_J_Rimmer
                                • May 2024
                                • 801
                                • Arnold
                                • North Wales
                                #165
                                Ah okay, for some reason I assumed you sprayed it. Thanks Mike, not being much of an airbrush man that makes life easier. Thanks for taking the time to answer, it's appreciated.
