1/35 scale Centurion Mk.12
  • Scratchbuilder
    • Jul 2022
    • 2689
    #121
    Update - Camoflague net.... 60's 70's style...
    You can purchase cam nets in various materials from a decal (AFV Club) to etch brass (Eduard) and I have tried them all. I was never satisfied with the end result, and so I set out to make my own, as used and got tangled up in and around anything that was not smooth, which will be fondly remembered when taking one down after a good German downpour of rain...
    So how do I start...
    The first item is to paint a sheet of paper (printer paper) usually about 3 inches (75mm) by the width of a sheet per colour. The paint used is your choice but I use acrylic, Tan, Brown and two greens.
    I paint Tan on one side, and once dry I paint the other side a shade of Green. Then repeat the same but using Brown and once dry, the other side is painted a lighter shade of Green.
    This is then cut into strips about 1mm to 1.5mm wide...
    The strips are gathered into about a half dozen and the ends levelled to remove the unwanted white paper. These are then fed through a piece of tube, in this case some plastruct tube, but any tube can be used, as all it is doing is keeping the strips together.
    Here you can see the strips being fed through the tube which has been taped to a spare piece of wood, the length (3mm) has been measured out and with a sharp knife blade cut into the relevant lengths. For cutting I used a #10 round scalpel blade and used a rolling motion to cut the bits to stop them flying all over the place.
    These are then collected together and placed in a tub.... This is an old 35mm film tub..
    For my netting I use some netting supplied by Fields of Glory models, but ordinary medical gauze can be used but the holes are a bit hit and miss and the material is a bit on the 'hairy' side.
    This is then placed over an open box without stretching it too much...
    And now we are ready for the fun part....
    I use a mix of diluted pva glue which is sprayed over the net through my old Badger 250 airbrush which I use for 'dirty jobs'...
    The pva will attach itself to the netting and once this has been done the camoflague bits are sprinkled over the whole net.
    This is then turned upside down to stand on the four 'legs' and the loose cam bits will drop off and the loose bits in the box will also pour out...
    Once the first side is dry, I left mine overnight, then the other side can be repeated and left to dry. I left mine for a couple of days to dry and then removed it from the box and trimmed to size. I then gently rolled it into a ball to break the stiffness and to loosen any bits that were not quite attached, opened it out and you can see the results below...
    The net is now ready for wrapping around the barrel of my Centurion once the vehicle has been painted.
    Mike.
    • scottie3158
      • 14201
      • Holbeach
      #122
      There is nothing more enjoyable than taking down a wet cam net in the dark and it magically snagging on everything lol. That is a great SBS.
      • Airborne01
        • Mar 2021
        • 3968
        • Steve
        • Essex
        #123
        Even white Arctic cam ones can give you that intense frisson of enjoyment!
        • Neil Merryweather
          • Dec 2018
          • 5185
          • London
          #124
          brilliant , thanks Mike.
          • Richard48
            • 1892
            • Richard
            • Clacton on Sea
            #125
            Superb nets Mike.I bought myself an Afv Club Centurion Mark 5 with dozer blade last week.Think this one will be one used in Suez 1956.Ive got some Bison decals for Suez crisis vechiles.
            Great work as always.
            Rich.
            • Scratchbuilder
              • Jul 2022
              • 2689
              #126
              Many thanks for the comments...
              Paul & Steve, had many a shower, trip into the mud and learned lots of new words and sayings....
              Neil, many thanks.
              Rich, Lots of extra parts in the box. Stage 8 I think it is, the louverd parts. I assembled them on a piece of flat metal first to save the juggling act of three hands and then attached them to the bulkhead part C42. The plastic/rubber tracks leave a lot to be desired, I would get a set of their (AFV) workable tracks, at least you can assemble and the glue them in position.
              Mike.
                • 15692
                That's an excellent, and very useful, SBS. Safety filed away in my little book of nicked ideas
                • Richard48
                  • 1892
                  • Richard
                  • Clacton on Sea
                  #128
                  Neil, many thanks.
                  Mike.
                  Many thanks for tip mike.Valuable info indeed.Will get some addy on tracks.
                  Rich
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #129
                    Just a couple of pics before I retire to slumberland.... I cannot have a sandwich because the hound got onto the table and decided to devour the butter that was left open by SWMBO, and natuarally I got the blame for shutting the dogs in the kitchen so she could eat her diet meal in peace.....
                    "That's ok love, I'll eat the stale digestives with a bit of Cheddar and a bag of crisps, mug of tea? Of course will make my own...."
                    • Neil Merryweather
                      • Dec 2018
                      • 5185
                      • London
                      #130
                      More bonkersness!
                      • scottie3158
                        • 14201
                        • Holbeach
                        #131
                        Fabulous mate.
                        • Si Benson
                          • 3572
                          #132
                          Excellent work on the camo net Mike :thumb2:
                          • JR
                            • May 2015
                            • 18273
                            #133
                            I'm taking up Free Style Ironing after seeing this.
                            • Scratchbuilder
                              • Jul 2022
                              • 2689
                              #134
                              Ironing on its way....:smiling5:
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #135
                                Thanks Si, pleased you liked it.
