Having bought my Tiger a couple weeks ago it has sat in the shed on the shelf while i decided what to do with it, was just going to leave it and get it out when the little uns were about to keep them amused but little things started to bug me so i thought i would have ago at making it into something more like the real thing.
Never having built or owned anything this size or type before i was a bit dubious about messing around with it but as soon as the first screws came out i couldn't stop myself so i took a couple pictures along the way to help me put it back together and help anyone else that is thinking of sprucing up their Tiger.
My tiger as it came out of the box next to a 1/35 m10 which is the only other tank i've built and that had no instructions and parts missing.
[ATTACH]21758.vB[/ATTACH]
I wanted to strip it down to its major components so i could give it paint job so first the drive wheels came off by removing the centre caps and undoing the allen bolts.
[ATTACH]21768.vB[/ATTACH]
The tracks could be removed then and placed to one side, depending on finances i may buy the metal track and drive sprocket set.
Next was to unscrew the 6 screws that were hidden under the tracks and the ones visable on the bottom.
[ATTACH]21765.vB[/ATTACH]
Once these were removed i undid the air cleaner pipe brackets to allow the top of the hull to part from the bottom, i didn't want to force the pipes from the air cleaners so i undid the cleaners from inside and left them attached as one piece
[ATTACH]21766.vB[/ATTACH]
[ATTACH]21763.vB[/ATTACH]
The upper hull can now be opened up fully and the white control plug and antenna be disconnected
[ATTACH]21759.vB[/ATTACH]
With the upper hull upside down you can see the ring gear that allows the turret to pivot, all the turret wiring goes through this ring gear, i couldn't find a way of disconnecting just the turret power from the rest of the wiring so i marked the cables and cut them so i could re-solder them later
[ATTACH]21757.vB[/ATTACH]
Removing the 3 ring gear screws the turret comes away complete, i then removed the tow cables and other parts i could, the jack and base are glued and the tools and boxes are moulded to the hull, so i will remove these and source a tool set and equipment to replace other parts
[ATTACH]21764.vB[/ATTACH]
[ATTACH]21761.vB[/ATTACH]
[ATTACH]21760.vB[/ATTACH]
Cheers for reading
Darren
[ATTACH]28656.IPB[/ATTACH]
[ATTACH]28657.IPB[/ATTACH]
[ATTACH]28658.IPB[/ATTACH]
[ATTACH]28659.IPB[/ATTACH]
[ATTACH]28660.IPB[/ATTACH]
[ATTACH]28661.IPB[/ATTACH]
[ATTACH]28662.IPB[/ATTACH]
[ATTACH]28663.IPB[/ATTACH]
[ATTACH]28664.IPB[/ATTACH]
[ATTACH]28665.IPB[/ATTACH]
[ATTACH]28666.IPB[/ATTACH]
[ATTACH]28667.IPB[/ATTACH]
[ATTACH]28668.IPB[/ATTACH]
[ATTACH]28671.IPB[/ATTACH]
Cheers for reading
Darren
