Dragon - 1/35 - Sd.Kfz.164 Nashorn
  • bluriusz
    • May 2012
    • 400
    Ok guys, I'm just about to start this beast.
    Over 700 pieces, some pe parts, brilliant barrel plus AFV 88mm ammo kit. It's gonna be great
    [ATTACH]59248.vB[/ATTACH]
    Now the question to you. Which unit should I do?
    1-[ATTACH]59249.vB[/ATTACH]
    2-[ATTACH]59250.vB[/ATTACH]
    3-[ATTACH]59251.vB[/ATTACH]
    Regards
    Bart
    [ATTACH]61043.IPB[/ATTACH]
    [ATTACH]61044.IPB[/ATTACH]
    [ATTACH]61045.IPB[/ATTACH]
    [ATTACH]61046.IPB[/ATTACH]
    Nice choice!!
    I think the Dragon kits are the best so far. I do a Panzer IV with this tracks, and you can do amazing works with it! I wish to build another, now than I have learn more things.
    That's a fantastic kit to weathering the inside part, will do old and used?
    Mmmm...Ok, will give my vote!
    Polux
    • mossiepilot
      • Jul 2011
      • 2272
      Wow Bart, that is a beast. Must admit I couldn't decide between each of the schemes either, but I voted for the one I think looks the best.
      Tony.
        Gotta go with No2 buddy nice little tigerstrip
        Martin
          Hi Bart they all look nice, but I'd go for the 2nd scheme myself....just looks better, good luck!
          Tom
          • bluriusz
            • May 2012
            • 400
            Hi all,
            Little update. Camo pattern no 2 have won and it will be in initial version of vehicle. I already started making the model, but wanted to show a bit more then assembled wheels
            [ATTACH]59679.vB[/ATTACH][ATTACH]59680.vB[/ATTACH][ATTACH]59681.vB[/ATTACH][ATTACH]59682.vB[/ATTACH][ATTACH]59683.vB[/ATTACH][ATTACH]59684.vB[/ATTACH][ATTACH]59685.vB[/ATTACH]
            Some observations on this Dragon kit.
            Assembly guide is a big f***n mess. Excuse my language. Some parts are on the pictures, but not described which one is it and you need to search through all spruces to find it. The same is with marking version of th vehicle (early, initial of modified), is a struggle to figure it out what is what. Second thing, why the hell you have workable tracks if you need to cement wheels to the hull, because they are loose and no rubber inserts in the kit.. Will need to find some.
            apart from that, kit is great. Everything fits better than fist to a mug.
            Regards,
            Bart.
            [ATTACH]61445.IPB[/ATTACH]
            [ATTACH]61446.IPB[/ATTACH]
            [ATTACH]61447.IPB[/ATTACH]
            [ATTACH]61448.IPB[/ATTACH]
            [ATTACH]61449.IPB[/ATTACH]
            [ATTACH]61450.IPB[/ATTACH]
            [ATTACH]61451.IPB[/ATTACH]
              • 22770
              Nice start Bart looks very detailed even without the PE parts
              • bluriusz
                • May 2012
                • 400
                Update
                I've finished the cannon with mounting. Quite a lot of work I must say, but I'm very happy with the result.
                [ATTACH]60017.vB[/ATTACH][ATTACH]60018.vB[/ATTACH][ATTACH]60019.vB[/ATTACH]
                Slowly getting there
                Bart.
                [ATTACH]61758.IPB[/ATTACH]
                [ATTACH]61759.IPB[/ATTACH]
                [ATTACH]61760.IPB[/ATTACH]
                  Go luck Bart, looking great so far. Some really nice detail even before painting etc...but 700 pieces would do my head in.
                  • mossiepilot
                    • Jul 2011
                    • 2272
                    A cracking start and the detail is impressive. Looking forward to seeing more.
                    Tony.
                      Dragon is like Rolls Royce among others models. Highly detailed and quality parts. I'll be watching your built. It's the one of most interesting Germans vehicles. Good luck. Bart.
                      • bluriusz
                        • May 2012
                        • 400
                        Hi guys,
                        sorry for a long break, but I've been on holidays. Came back couple days ago and back to work on mighty Nashorn.
                        I need to speed up a little bit, as I wanted to join helicopter GB
                        Have almost finished gun.
                        Just wash to be done on this. That's my first time I used this hairspray technique. Tell me if you like it
                        [ATTACH]61864.vB[/ATTACH][ATTACH]61865.vB[/ATTACH][ATTACH]61866.vB[/ATTACH]
                        [ATTACH]63348.IPB[/ATTACH]
                        [ATTACH]63349.IPB[/ATTACH]
                        [ATTACH]63350.IPB[/ATTACH]
