accademy M311 ambulance.
    This is going to be my next victim,
    [ATTACH]73649.IPB[/ATTACH]
    I'll be adjusting it to be a medivac ambulance, and scratching most of the interior and extras needed, might pop it on a simple dio base as the main subject, not decided if there will be figures included yet.
    Will pop some pictures up tomorrow when I have more than a painted interior to the hull to show.
    • 22771
    Nice Colin, looking forward to seeing what you do with this one
      Very interesting Colin!!
      I like your idea.
      • mossiepilot
        • Jul 2011
        • 2272
        That sound like a nice build idea, I'll look forward to seeing where you go with this.
        Tony.
        • eddiesolo
          • Jul 2013
          • 11193
          Sounds good Colin.
          Si
            well for a start I've sprayed the inside of the hull and all the interior parts white with a cheapo rattle can.
            The engine is matt black and will dry brush and weather it in situ as i find it easier that way and it seems to blend better.
            There's not much following the instructions for the interior as it's mostly going to be scratch built stretchers etc
            [ATTACH]73673.IPB[/ATTACH]
            [ATTACH]73674.IPB[/ATTACH]
            [ATTACH]73675.IPB[/ATTACH]
              Got the interior together, nice detailing on the instruments etc
              I've added the rod supports for the canvass stretchers, they need a coat of paint.
              [ATTACH]73715.IPB[/ATTACH]
              [ATTACH]73716.IPB[/ATTACH]
              [ATTACH]73717.IPB[/ATTACH]
              [ATTACH]73718.IPB[/ATTACH]
              [ATTACH]73719.IPB[/ATTACH]
              [ATTACH]73720.IPB[/ATTACH]
              Next up is stretchers, sheets, a little bench for opposite the stretchers, some oxygen/anaesthetic bottles...
              that should fill the inside up a bit.
              • eddiesolo
                • Jul 2013
                • 11193
                Originally posted by \
                Got the interior together, nice detailing on the instruments etcI've added the rod supports for the canvass stretchers, they need a coat of paint.
                [ATTACH]73196[/ATTACH][ATTACH]73197[/ATTACH][ATTACH]73198[/ATTACH][ATTACH]73199[/ATTACH][ATTACH]73200[/ATTACH][ATTACH]73201[/ATTACH]
                Pftttttttttt...half of that lot would be lost if I was trying to make it...how small is that fire extinguisher!
                Saying that, it could be really 1/24 scale and Colin is actually 12 feet tall
                This is looking good mate, those tiny bits are looking the part and I like the subtle weathering. Nice work mate.
                Si
                  Very detailed work Colin.
                  I feel this will be a great build!!
                  Lovely start.
                  Polux
                  • flyjoe180
                    • Jan 2012
                    • 12429
                    • Joe
                    • Earth
                    Nice work Colin
                    • Andy2035
                      • Aug 2011
                      • 730
                      Hi Colin,
                      Looking great so far Sir, love seeing your detailing work again...
                      Andy...
                        Thank you chaps, appreciated!
                        Added the stretchers, bench and sheets to the interior
                        [ATTACH]73780.IPB[/ATTACH]
                        [ATTACH]73781.IPB[/ATTACH]
                        tidied up the instruments a bit
                        [ATTACH]73782.IPB[/ATTACH]
                        made some O2/gas type bottles (ends of paintbrushes with wire for the pipe and sprue slices for the guages, the decals are just random spares that looked ok (ish))
                        The first aid box is an ammo box (i think) from an accessories kit
                        [ATTACH]73778.IPB[/ATTACH]
                        [ATTACH]73779.IPB[/ATTACH]
                        Got some non-slip pads on the drop down rear door (wet and dry cut to shape)
                        [ATTACH]73783.IPB[/ATTACH]
                        Next up is brackets for the bottles and then start work on the wheels .... and suspension.
                          • 22771
                          Your showing off Colin..
                          Great work mate
                          • eddiesolo
                            • Jul 2013
                            • 11193
                            Superb Colin, just brilliant.
                            Si
                              That's them done and in situ.
                              [ATTACH]73787.IPB[/ATTACH]
                              [ATTACH]73788.IPB[/ATTACH]
                              favorite job next .....not! ...... the wheels
