Trumpeter 1/35 SU-152 (early)
    Hi all.
    Here's my next project:
    Its a nice-looking kit & my first by Trumpeter. I do love Russian armour for the scope they give to weathering.
    Here are the usual sprue shots:
    [ATTACH]78804.IPB[/ATTACH]
    [ATTACH]78805.IPB[/ATTACH]
    [ATTACH]78806.IPB[/ATTACH]
    [ATTACH]78807.IPB[/ATTACH]
    [ATTACH]78808.IPB[/ATTACH]
    As well as the small amount of
    PE, there is a turned aluminium barrel & separate link tracks. As my compressor has bit the dust, I'm stuck with rattle cans for this one, so thank god it's not a German late-war AFV!
    More to follow....
    Cheers Patrick
    [ATTACH]78803.IPB[/ATTACH]
    Fantastic choice Patrick!!
    I like to follow this kind of threads, well in fact, these not habitual tanks
    I'm sure you will do an excellent build
    Polux
    • tr1ckey66
      • Mar 2009
      • 3592
      Hi Patrick
      That's a great subject for a model kit. The kit itself looks very detailed, judging by the sprue shots, and should build into a great armoured vehicle. Russian AFVs, although usually one colour, do give a good (and often big!) canvas for applying weathering techniques.
      Looking forward to seeing this progress.
      Paul
      • yak face
        • Jun 2009
        • 13840
        • Tony
        I really like the look of this beast Patrick -that gun is pretty huge!Looking forward to seeing the build , cheers tony
          Thanks guys! Got a bit more done today-the kit is a good'un, goes together without any drama:
          First the hull section:
          [ATTACH]78844.IPB[/ATTACH]
          [ATTACH]78845.IPB[/ATTACH]
          Then the wheels:
          [ATTACH]78846.IPB[/ATTACH]
          So after this will be the tracks. I'm going to assemble, paint & weather the lower hull in its entirety as once the fenders are on, it will be nigh-on impossible to fit or reach the upper tracks.
          Cheers Patrick
          • monica
            • Oct 2013
            • 15169
            will tag along on this one nice to see some think difference, and a nice start,
            look forward to next update
              Nice start Patrick.
              All the lower hull...will wait this update mate
                Well guys & gals, the next bit is every armour builder's favourite- link & length track! If you see the sprue shot, half the links have 6 sprue connections& tthe rest have 4. There's 12 of these sprues so its a lot of clipping & sanding for me!
                [ATTACH]78858.IPB[/ATTACH]
                Thanks for looking!
                Patrick
                  3 hours of hard work have resulted in this lot!
                  [ATTACH]78876.IPB[/ATTACH]
                  Only 180 links there! So now it's on to getting them into lengths ready for gluing.
                  My technique is to stick a length of masking tape on the bench, add over this a length of double-sided tape & then another strip of masking tape with the sticky side up.
                  This method both keeps the strips from moving & allows the track links to be assembled tightly together, as in the pics:
                  [ATTACH]78877.IPB[/ATTACH]
                  [ATTACH]78878.IPB[/ATTACH]
                  [ATTACH]78879.IPB[/ATTACH]
                  This shows the strips with the track ready for positioning on the tape.
                  Here is the 2 lengths for one side. I add
                  extra thin cement & leave them for 15-20 minutes so the glue takes hold:
                  [ATTACH]78883.IPB[/ATTACH]
                  Next is to drape them over the wheels to get the desired sag effect
                  [ATTACH]78889.IPB[/ATTACH]
                  [ATTACH]78891.IPB[/ATTACH]
                  Leave them to set & then they can be painted.
                  Cheers Patrick
                  [ATTACH]78890.IPB[/ATTACH]
                  • spanner570
                    • 15402
                    So this is the beast you mentioned when we were exchanging P.M's!
                    Great choice, and I'm sure you'll give it the usual excellent Dubster72 treatment you gave your previous models here on S.M.
                    Logged in for future reference......
                    Ron
                      Haha cheers Ron! Yes, it's the ' beast killer'! Fingers crossed it comes out ok!
                      • spanner570
                        • 15402
                        Uncross yon fingers....that will not be neccessary.
                          Fantastic tip Patrick!!
                          I like it mate!!
                          Keep up the good work
                          Polux
                            Small update on this one!
                            The lower hull, wheels & tracks are done, just a matter of attaching them!
                            Sorry that the pictures aren't much good, I'm forced to use my phone's inadequate camera for now!
                            [ATTACH]79322.IPB[/ATTACH]
                            [ATTACH]79323.IPB[/ATTACH]
                            [ATTACH]79324.IPB[/ATTACH]
                            [ATTACH]79325.IPB[/ATTACH]
                            There will be sone
                            some more work with pastels/pigments once the majority of the build is finished.
                            Thanks for looking in!
                            Patrick
                              Looks pretty nice so far Patrick as these tracks as well!
