Trumpeter 1/35 SU-152 (early)
    Very very nice work Patrick.
    Errr....I don't understand! The base colour is acrylic, not? And then you add the oil colours...or you have painted all the tank directly with oils
      Thanks for your kind words Tommy Moni & Polux!
      Polux the base coat is gloss green acrylic & then I use oils to vary the colour. Some people use the ' dot wash ' technique, but I've changed this slightly by adding tiny dots of paint to the area I'm working on. These dots are complimentary colours, different shades of green & brown. Then I use a short stiff brush to spread the paint around & blend it together. It adds a nice visual effect.
      Patrick
        Thank you very much for the advice Patrick
        • flyjoe180
          • Jan 2012
          • 12426
          • Joe
          • Earth
          #34
          Looks good Patrick, and the effect has worked well. Thanks for explaining it.
          • tanktrack
            • Jun 2012
            • 1429
            #35
            I am a lover of Russian armour and like what you have done Patrick the track tip is a belter thanks for that and the paint looks great also well done good luck to the finish line
              Glad to have helped guys! Your kind words keep me inspired
                Some quality painting going on their Patrick, well done. Cheers Derek
                  Looks absolutely great! What did you use to cover the tracks while painting?
                  cheers Benny
                    Originally posted by \
                    Looks absolutely great! What did you use to cover the tracks while painting?cheers Benny
                    Thanks Benny, I used an old pair of latex gloves, stretched around the tracks! Works well & much easier than masking them with tape.
                      Great idea! If using friuls, it is not necessary but with other tracks it might be a great help! thx for the hint
                        Whilst waiting for other things to dry / glue / cure / get better by magic (!), I thought I'd bring this one out of its box.
                        Most of the new stuff is chipping, both by hand & sponge - I'm going for a heavily weathered look.
                        [ATTACH]83521.IPB[/ATTACH]
                        [ATTACH]83522.IPB[/ATTACH]
                        [ATTACH]83523.IPB[/ATTACH]
                        [ATTACH]83524.IPB[/ATTACH]
                        Next will be some dusty pastel work
                        Thanks for looking
                        Patrick
                          That`s a cracking build Patrick, looks great, really like the weathering effect on this kit, looking forward to see what you do next on the pastel work
                            Just caught up with this Patrick that looks bledy brilliant
                            • john i am
                              • Apr 2012
                              • 4019
                              #44
                              Great paint and weathering on the tank Patrick look forward to the dust
                              • monica
                                • Oct 2013
                                • 15169
                                #45
                                superb work Patrick, a great job with the weathering, looking forward to the dusting
