Wow,i was reading the last 2017 post here,....
Yes indeed...so many post here!!
That's why i start the next couple months some kit's here
MARDER SERIE :
Marder III Ausf M was almost the same type as the Marder III Ausf H
The Marder III was produced in two variants – Ausf H and Ausf M. They were based on the Panzerkampfwagen 38(t).
Compare it....
Specifications
Model: Ausf H Ausf M
Weight: 10800kg 10500kg
Crew: 4 men 4 men
Engine: Praga EPA/2 / 6-cylinder / 140hp Praga AC / 6-cylinder / 140hp
Speed: Road: 35km/h Road: 42km/h
Cross-Country: 24km/h
Range: Road: 240km Road: 185km
Fuel Capacity: 218 litres 218 litres
Lenght: 5.77m 4.95m
Width: 2.16m 2.15m
Height: 2.51m 2.48m
Armament: 75mm Pak 40/3 L/46
1 x 7.92mm MG37(t) 75mm Pak 40/3 L/46
1 x 7.92mm MG34
The Ausf H carried 38 rounds of ammunition, while Ausf M had only 27 rounds
From April 1943 to May 1944, BMM produced 975 Ausf M models.
The Ausf H (Heckmotor-rear engine) had the fighting compartment in a central forward location, while the fighting compartment of the Ausf M (Mitte-mid engine) was at the rear.
And now the kit : Dragon nr 6464,937 parts (562 in grey styrene, 240 “Magic Track” links, 118 etched brass, 16 clear styrene, 1 length twisted steel wire)
I start with the inside of the tank...problem with the airbrush to paint the inside of the wheels.
[ATTACH]286057[/ATTACH]
The Engine part...
MARDER SERIE :
Compare it....
Specifications
Crew: 4 men 4 men
Lenght: 5.77m 4.95m
Width: 2.16m 2.15m
Height: 2.51m 2.48m
1 x 7.92mm MG34
The Engine part...
