Britsh 25 PDR. Field Gun & Quad Gun Tractor
  • stillp
    • 8093
    • Pete
    • Rugby
    #121
    Oil filters used to be a replaceable element inside a steel can that was usually either silver, or engine colour.
    • Si Benson
      • 3572
      #122
      My god man, you’ve gone full upgrade again haven’t you!
      I’ll get matron to increase your medication till it calms down....she may give you a sponge bath too, if your unlucky:tired:
      I cannot keep up with you mate....looks like your enjoying yourself so I’ll just nod and smile:nerd: splendid work sir....keep it up:thumb2:
        Jakko you have let the side down!:smiling3: I cannot understand why you didnt do 144 rivets on the back of the wheels so no one can see it. I am surprised you can sleep at night knowing they are not there.:smiling5::smiling3::smiling::thumb2::thumb2 :
        That must be the cause of my insomnia, yes …
        I made a start on the engine. First question is what does the white styrene rod represent??.
        I would guess the starter motor. It’s on the side of the engine, if there’s an axle inside it’ll be parallel to the crankshaft, and it seems to connect to the front of the transmission housing.
        Here’s a real CMP engine:
        Looks like a starter motor to me.
        • Steve Jones
          • 6615
          #124
          Hi Everyone
          Pete/Jakko - Many thanks guys with the help on the thingy me jig at the bottom of the engine:thumb2:
          Si - It's starting to get away from me now and I just cant stop:smiling5:
          • scottie3158
            • 14201
            • Holbeach
            #125
            Steve,
            More excellent scratchduggery and etch work.
            • JR
              • May 2015
              • 18273
              #126
              Absolutely knocked out Steve with the detail. I just don't know how you manage to achieve such work in your modelling.
              Certainly take my hat off to you. Well done mate.
              Are you sure you are not related to the one known as MR T from up north, , he has trained you well.
              John.
                • 15692
                Hi Steve
                Just caught up. So much great work. Love the engine and particularly the bumper damage. I definitely appreciate the 'warts and all' style of your blogs.
                • BigGreg
                  • 2182
                  #128
                  Steve..... what a fantastic work.... your "scratchery" is superb :thumb2::thumb2::thumb2::thumb2::thumb2:
                  • rtfoe
                    • 9083
                    #129
                    Steve, that's good work on the scratchery. Take note on the alignment of parts and use the lines on the work matt as a guide. I believe the parts in the last picture have not been glued yet and will need adjustment or it might pose a problem later in assembly. Everything else is fine...:smiling6: so much to see I'd get cross eyed if I had to do what you did.
                    The Padwan has done well Jedi T...:smiling2:
                    • Steve Jones
                      • 6615
                      #130
                      Hi Everyone
                      Cheers Paul. I appreciate your support mate. Now get on and do some building yourself!:smiling5:
                      They say I am Mr T's love child but I'm not so sure John:smiling5::tears-of-joy:. Hope you get better soon. That will teach you to sniff all that CA:smiling2:
                      There would be more "warts" Jim but we would be here all day:smiling5:
                      Thanks Greg:thumb2::thumb2:
                      When it was attached to the front Richard everything squared up okay as you will now see:thumb2::thumb2:
                      • rtfoe
                        • 9083
                        #131
                        Hi Everyone
                        :thumb2::thumb2: Now I see the part above was the old plastic put there for comparison.
                        The white plastic and metal parts are starting to overpower the rest of the kit. :smiling6: Looking good. :thumb2:
                        • SimonT
                          • 2824
                          #132
                          Don't forget to impart a curve to the leaf springs Steve they are looking a bit flat - they look like they may be a little short to accommodate the curve :thinking:
                          • JR
                            • May 2015
                            • 18273
                            #133
                            Steve,
                            See, even at this early hr He from the Darkside is on the prowl. Take heed of the wise one.
                            As for me..... Can't sleep, so mug of tea and the forum to while away the night. :worried::sad:.
                            Question....... On the second to last photo there's a plate in white across the frame ( where the two fuel tanks are .) that detail of the lipping around the inspection hole is top rate, so small but effective.:thumb2:
                            John.:sick:
                            • Steve Jones
                              • 6615
                              #134
                              Richard - That's the look I like as well. One day I will be brave and leave as is with no paint on:smiling2:
                              Mr T/Mr Race - It's bad enough that I have to start work at 4 in the morning but to have you both blogging at 2 and 3.15 is a bit extreme:smiling3:. As for the springs I tried to bend them as I made them but they just sprung back to their original shape. I assume I have to use super super CA glue when I attach them to the chassis and bend them then. If you have any other suggestions from the dark side I am all ears. I would like to take credit for the support beam across the chassis JR but that is how it came off the sprue and I made it fit snugly in place
                              • JR
                                • May 2015
                                • 18273
                                #135
                                Richard That's the look I like as well. One day I will be brave and leave as is with no paint on
                                Mr T/Mr Race It's bad enough that I have to start work at 4 in the morning but to have you both blogging at 2 and 3.15 is a bit extreme. As for the springs I tried to bend them as I made them but they just sprung back to their original shape. I assume I have to use super super CA glue when I attach them to the chassis and bend them then. If you have any other suggestions from the dark side I am all ears. I would like to take credit for the support beam across the chassis JR but that is how it came off the sprue and I made it fit snugly in place
                                What ever mate It's still brilliant work.
                                Myself I would suggest fire to bend into shape, but my experiments usually end in complete disaster. HTH
                                John :sick:
