Taking a short break from applying rib tapes to my SSW D.III I'm lining up for my next build......................[ATTACH]311572[/ATTACH]
I'll put up some detail shots:
Suspension mount[ATTACH]311558[/ATTACH]
Final Drive mount[ATTACH]311559[/ATTACH]
Upper Hull edging[ATTACH]311560[/ATTACH]
Drivers' hatch
[ATTACH]311561[/ATTACH]
Side hatch - moulded in place[ATTACH]311567[/ATTACH]
Top of the turret - non-slip & hatch opening[ATTACH]311568[/ATTACH]
As you can see, all parts are crisply moulded, and no flash anywhere
Road wheel & drive sprocket[ATTACH]311562[/ATTACH][ATTACH]311563[/ATTACH]
Tracks are link & length, with the hollow guide horns in strips - track sag is built in on the top runs
[ATTACH]311569[/ATTACH]
There are some very fine parts - these are the front fender mounts/springs
[ATTACH]311565[/ATTACH]
One of the weakest points is the barrel & muzzle brake - split into multiple parts - a lot of careful assembly & clean-up
[ATTACH]311570[/ATTACH][ATTACH]311571[/ATTACH]
Decals are generally generic, but then the Russians don't go for a lot of identification.
I think I'm going for a camo scheme, so I got this AK set...........................
[ATTACH]311573[/ATTACH]
Construction will start as soon as the SSW D.III is completed
Drivers' hatch
