1/87 Four Deuce Chem. mortar section
  • minitnkr
    Charter Rabble member
    • 7541
    • Dayton, OH USA
    My ref. material is less than stellar for this project, so comments/criticisms are encouraged as I plunge ahead. Much of what I have read indicates they originally used 2.5 ton trucks but they were too noisy & ungainly in Sicily/Italy action. Some sources say they went to 3/4 ton WCs & others say jeeps w/trailers. I am favoring the WC (beep) option as these were self sufficient units and used a lot of ammunition. Also have some photo evidence. I'm using ROCO WCs, 1/4 ton trailers OOB pretty much and am also using the ROCO 81mm mortars as the basis for the 4.2" (107mm) conversion as they were way too big to use as intended. Progress pic so far. They also were expected to provide their own security so I'm giving them a MA Deuce & some bazookas.
    [ATTACH]313004[/ATTACH]
    PaulE
  • JR
    • May 2015
    • 18273
    Paul.
    Your straight in with this, nice bazooka's in the front there. How many would they have had.? Will grab a seat before the Rabble arrive.
    Dzhon.
    • Steve Jones
      • 6615
      More miniature madness:thumb2: You have a lot on the go at the moment. How many vehicles are involved in this project now??
      • minitnkr
        • 7541
        • Dayton, OH USA
        Gen. Patton was so impressed w/their performance in Italy he said no regiment should deploy to Europe w/o at least an attached company of these very accurate and effective mortars. PaulE
        • minitnkr
          • 7541
          • Dayton, OH USA
          Dzohn, my guess from several unit narratives was the battalion of 36 tubes (after 9/43 reduced from 48 due to crew shortages) tried to get the companies of twelve tubes each 13 bazookas & 50cal. MGs. because of many instances of crews having to defend their positions. I may have misspoke previously confusing platoon/section terms. Section consists of 8 men (not enough) to 1 mortar (36 tube battalion). PaulE
          • minitnkr
            • 7541
            • Dayton, OH USA
            Steve, upon further research I've replaced 2 1/2ton trucks & assoc. trailers with 3/4ton trucks with 1/4ton trailers in the mortar platoon. PaulE
            • minitnkr
              • 7541
              • Dayton, OH USA
              Further progress on chem mortar platoon. You can see the bazooka stowed at the windshield.
              [ATTACH]313266[/ATTACH]
              The mortar is in the trailer to keep it lined up while cement dries
              [ATTACH]313267[/ATTACH]
              Skin oil has etched these tweezers over the years. You can just make out the tiny 2nd Chemical decals.
              [ATTACH]313268[/ATTACH]
              C&Cs welcomed. PaulE
              • minitnkr
                • 7541
                • Dayton, OH USA
                Thanks Mick. Because these were managed by the Chemical Warfare Service & nobody was using gas they were the "red haired stepchild" of the supply chain, so were always short of everything assoc. with conventional war fighting. Often causing Corp & Army leaders to intervene. Units sometimes manufactured their own spare parts in local factories.
                The German prisoners in Italy thought they were automatic cannon due to the quantity of rounds hitting so close with such ferocity. Their explosive power was equal to the 10.5cm howitzer but a good crew could get 30 rounds a minute in the air for short periods. Multiply this by 48 tubes in a company & you get the idea. The tubes would overheat sometimes causing the round to launch before hitting the trigger. Once so hot the trigger melted. The rifled tube 'goon gun' accuracy was legendary. 15 rounds in a 30' radius not unusual. Anecdotes of taking out snipers with one round & taking out individual tanks bolstered their reputation. PaulE
                • JR
                  • May 2015
                  • 18273
                  Going to look the part Paul .
                  Just been told my bench is getting like yours :thumb2: that is quite impressive :smiling5:
                  Dzhon
                  • minitnkr
                    • 7541
                    • Dayton, OH USA
                    Thanks Dzohn & Mick. We know where stuff is.....usually.
                    More progress, mortars & personal weapons almost ready for paint.
                    I must confess, jeeps w/trailers are usually around $20@ whereas WCs are more like $4 to $8@. TO&E hints at two jeeps with trailers/mortar & one WC/mortar, so economics has influenced my choice of vehicle after reading 2 1/2 trucks were out of the picture. Plus I had some extra WCs & 1/4ton trailers.
                    [ATTACH]313355[/ATTACH]
                    C&Cs encouraged. PaulE
                    • JR
                      • May 2015
                      • 18273
                      Think its always a good sign when your nearly ready to hurl some paint.
                      Knowing where stuff is ...... Well it was here once, but that was 10 minutes ago ! :smiling2:
                      Dzhon
                      • Mini Me
                        • Jun 2018
                        • 10711
                        Paul,
                        Looking good and coming together rather quickly. Thanks for the back ground info...always creates a lot more interest!
                        Rick H.
                        • PJR
                          • Jul 2018
                          • 74
                          Mortars looking good, thanks for sharing!
                          • Steve Jones
                            • 6615
                            Wonderful work as always Paul. Unfortunately you are going to have to educate an idiot. Where do the mortars go please?
                            • minitnkr
                              • 7541
                              • Dayton, OH USA
                              On clear firm ground, Steve, but not rock. Usually a thousand yards behind the front line for smoke operations. For infantry support, wherever needed. Sometimes right up front. They were limited to an effective range of 2000yds very early, but were firing out to over 4000 by late 44. They tried a couple sp mounts, but none passed trials. A side note--they lost a platoon per company when they were reduced to 36 tubes so the companies were three 4 tube platoons. So now I have to come up w/another WC & "goon gun". PaulE
