1:35 Dragon 6287 88mm Flak 37 (build version: 37, transport, extended shield)
  • Gauge1TrainsDK
    • Mar 2017
    • 407
    Good evening, everyone!
    I was asked to put up pictures for this build, so they follow below. So far, there has been no complications. The kit makes really great sub-builds and it's easy enough to assemble so far. Though I should say, I am only about to begin step 8 on a 35-ish step build.
    There are mold lines on sprue C, but they are "Dragon-lines", so they are very unobtrusive albeit in need of light cleanup.
    I found the chain links too large for the scale, and the measure of 1,2 cm was clearly too long. Should more likely have been the approx. 0,6 - 0,8 cm I used for the other side plate holding the gun.
    Any questions or suggestions, feel free to join in!
    Happy modelling,
    Christian
  • Gauge1TrainsDK
    • Mar 2017
    • 407
ID:	1107773Click image for larger version
ID:	1107774Click image for larger version
ID:	1107775Click image for larger version
ID:	1107776Click image for larger version
ID:	1107777Click image for larger version
    • JR
      • May 2015
      • 18273
      Looks quite a complex build looking at those instructions Christian and the gun looks very neat and clean .
      Will grab a seat .
      • Gauge1TrainsDK
        • Mar 2017
        • 407
        Thank you.
        The build is not as complex as it seems. Just focus on one number at a time. Usually, Dragon's pieces fit into each other like specially made Lego pieces, so it's usually much easier than someone like ICM, Heller, and Ark Models, to me.
        • Gauge1TrainsDK
          • Mar 2017
          • 407
          Step 8 complete!
          You can move the indicator inside the quarter circle
            • 18269
            Nice sharp detail on those parts.
            I notice that the decal sheet is from Cartograf so they should go down nicely too.
            • JR
              • May 2015
              • 18273
              Fantastic amount of detail .
              • Gauge1TrainsDK
                • Mar 2017
                • 407
                My understanding is that all Dragon kits come with Cartograf, except for maybe some very old ones. I think even Imperial series have Cartograf in some or many cases, but I would have to check what I happen to have.
                • Steve Jones
                  • 6615
                  Nice build Christian. I will tag along if I may. Have you decided which theatre of operation you are going to base your model on??
                  • scottie3158
                    • 14201
                    • Holbeach
                    Christian, Nice work so far.
                    • Gauge1TrainsDK
                      • Mar 2017
                      • 407
                      Thanks, guys!
                      Steve, I am considering both the 1945 two-tone sand yellow and brown camo as well as the German grey. Havn't decided, then!
                      • Steve Jones
                        • 6615
                        Just build two of em! LOL
                        • Gauge1TrainsDK
                          • Mar 2017
                          • 407
                          I do have four copies of the kit, including the one I am currently building, so it is "only" a matter of time.
                          Only...
                          • AlanG
                            • 6296
                            I'd love to get an 88mm and build it into a Flak diorama. Looking great so far
                            • JR
                              • May 2015
                              • 18273
                              Well that's made Steve happy with the colour scheme ! :smiling2::thumb2:
