1:35 Dragon 6287 88mm Flak 37 (build version: 37, transport, extended shield)
    Originally posted by Gauge1TrainsDK
    I do have four copies of the kit, including the one I am currently building, so it is "only" a matter of time.
    You could build all of them more or less the same, then make a diorama of an operational anti-aircraft battery …?
    You’d only need, oh, a couple of square metres and about 50–60 figures?
    • Gauge1TrainsDK
      • Mar 2017
      • 407
      #17
      You’d only need, oh, a couple of square meters and about 50–60 figures?
      Nice image, but they are far more likely to be built in transport mode to go on gauge 1 rail cars. :smiling:
      • minitnkr
        Charter Rabble member
        • 7547
        • Dayton, OH USA
        #18
        .......or an overrun battery w/no figs, or a flak tower w/88 on each corner w/12.8 zwilling in the center, or...., or.... The possibilities boggle the mind. PaulE
        • Gauge1TrainsDK
          • Mar 2017
          • 407
          #19
          I actually have a Zwilling from Takom. Don't have that kind of plan, though, but at the same time I do not know what to do with it.
            Now that would be a model I’d like to see, a 1:35 scale Flakturm. Take your pick which one:
            [ATTACH]362388[/ATTACH] (via Wikipedia)
            The one on the left was 70.5 m × 70.5 m × 39 m, so that makes almost a nice, round 2 × 2 metres diorama that only has to be about 125 cm tall including the guns. Piece of cake!
            Though now I’m seriously wondering if there are 1:300 or 1:285 scale 12,8 cm FlaK guns, which would make a thing like this actually feasible
            • minitnkr
              • 7547
              • Dayton, OH USA
              #21
              They (8.8 & zwilling) are available in 1/87. PaulE
              • Mini Me
                • Jun 2018
                • 10711
                #22
                Haven't found a state side source for 12.8 zwielling. Pardon the intrusion Christian.
                Your build is looking great so far. Cheers, Rick H.
                • Gauge1TrainsDK
                  • Mar 2017
                  • 407
                  #23
                  Thanks, Rick. No problem.
                  • minitnkr
                    • 7547
                    • Dayton, OH USA
                    #24
                    Sorry Christian, we get a little wound up sometimes. You're certainly doing this excellent model justice with a clean & tight build. PaulE
                    • rtfoe
                      • 9094
                      #25
                      I like clean and tight builds and you're doing great Christian...don't mind the Rabble :tears-of-joy: ...everyones a creative director of some sort or you could say we dream a lot.
                      • Gauge1TrainsDK
                        • Mar 2017
                        • 407
                        #26
                        No problem, guys. I wasn't that bothered by the scenarios, just thought I would not be doing it. Suggestions and input are always welcome!
                        • Gauge1TrainsDK
                          • Mar 2017
                          • 407
                          #27
                          Step 9 and thus the gun itself completed :smiling4: So far, it has been an almost entirely troublefree build with no guesswork. The placement of seat D21 on C29 had me wondering how far I should push the seat pin in, but I just decided to put it all the way and it seems to sit just fine. When the round mount is put underneath, I can cut a bit of the pin off without it being noticeable if I have to. Note! You should place C5 before C28 onto the gun, but I managef to squeeze C5 in behind it anyway.
                          It is definitely looking awesome and detailed! Well done, Dragon of 2005!
                          • Gauge1TrainsDK
                            • Mar 2017
                            • 407
                            #28
                            Status of the build. Next: Legs! This is a great looking model indeed, and I am glad I got past the intimidation of tackling the instructions. Things are much easier than they seem, to be sure!Click image for larger version
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #29
                              Won't that be fun to paint! Lots of nooks and crannies to work around when it comes to the wet stuff. BTW, nice looking Ford Maultier I spied in the back ground. Hope you post that when you get it done. Cheers, Rick H.
                              • Gauge1TrainsDK
                                • Mar 2017
                                • 407
                                #30
                                Unluckily, I lost the engine hood for the Maultier :-( Now, I am not sure how to finish it.
                                I paint using spray cans, then brushed for details and wash, so I am not at all troubled by the detail level here ;-)
