Trumpeter 1/35 3.7cm Flak 37 Auf Sd.kfz. 7/2 Early Version.
    Whilst waiting for another white basecoat to dry on the Beriev Be200, I've chosen the next build...................
    It was a toss up whether this went in the softskin section or here - but the flak gun is the important thing.
    This has been in the stash for a few years - the price sticker on the side is £36.99 - but I can't believe I paid that!!!!
    A lot of parts - a whole lot of them are the individual track links, but being a half track not that bad ( !! ). I'll be taking some sprue shots in the next day or so. There are 14 sprues for the vehicle, trailer & gun, 7 for the tracks, 4 small PE frets & 3 vinyl tyres.
    I think this will be painted using the ICM Acrylic Marder Set, to see how they perform!!
    • 18908
    Looks interesting Dave. Box art is nice as well….looks like a Greek setting to me…..
    • The Smythe Meister
      • Jan 2019
      • 6248
      DAVE!!
      Looks superb... I'm definitely in for the long haul on this one Sir
      Andy
      • JR
        • May 2015
        • 18273
        £ 36.99, what were you on ? Certainly not like you Dave .
        I shall sit with Mr Smith .
          In the bottom of the box, there was a small ziploc baggie with a RB metal barrel for this beast - a nice surprise!
            Sprue shots.......................
            Quite a boxful of bits..................
ID:	1162312Click image for larger version
ID:	1162313Click image for larger version
ID:	1162314Click image for larger version
ID:	1162315Click image for larger version
ID:	1162316Click image for larger version
ID:	1162317Click image for larger version
ID:	1162318Click image for larger version
ID:	1162319Click image for larger version
ID:	1162320Click image for larger version
            Such a miserable grey day, I had to use flash for the piccies. In consequence, the camera battery is now flat!
            I'll post up some details when it has recharged.
            • adt70hk
              • Sep 2019
              • 10411
              That is a lot of bits!!
                • Jan 2019
                • 6248
                Bring it on......
                .... I`m looking forward to this Dave!!
                Andy
                  A few detail shots:-
                  The chassis is flatpack, with substantial side rails
                  The tracks are 3 parts per link - 54 links per side...........................Click image for larger version
ID:	1162341Click image for larger version
                  Drive rollers
                  Outer roadwheel
                  The trailer has solid plastic tyres - unlike the 1/2 track, which has vinyl parts
                  Not another wheel, the winch drum ( with a bit of flash ) fitted underneath the load bed
                  Load BedClick image for larger version
ID:	1162350Click image for larger version
ID:	1162351Click image for larger version
                  The kit gun barrel compared with the RB metal replacement............
                  The PE frets: Some of which will not be used - the gun shields, for example ( bottom left )
                  The plastic bits are thin enough for me! Some tiny parts, but not microsurgery bad!
                  And I'm using this as a test of these ICM paints
                  Don't think much of the colour descriptions, but as long as they look the part, I'm not bothered
                  This really can be broken down into 3 models, the gun, the trailer & the vehicle, I may make one at a time!
                  Construction will commence soon
                    That’s looking interesting already. The parts look well-moulded, better than some Trumpeter I’ve seen, but I wonder if the fit is as well? I’ve got a Dragon Sd.Kfz. 7 (with a load bed, but no gun) waiting to be built, so it’ll be interesting to see how this kit compares to that in terms of construction.
                      Bet the big difference will be the instructions!
                        Chances are you’ve got the better kit in that respect, certainly
                        • Isitme
                          • Nov 2020
                          • 795
                          Dave,
                          I see the problem with the worry of you spending £36.99 on a kit. You were looking to the future and actually spent £6.99 on the kit and £30 on the box thinking that it could be converted into a suitcase for the hols.....
                          Looking forward to your magic on this one, I remember the old ESCI kits which included the half-track. Demag.
                          Mike
                            Originally posted by Isitme
                            Dave,
                            Mike
                            I seem to remember the Esci Demag with a 20mm gun mounted on the back..................that was a long time ago!
                            • Isitme
                              • Nov 2020
                              • 795
                              Yep! showing my age.....
