Trumpeter 1/35 3.7cm Flak 37 Auf Sd.kfz. 7/2 Early Version.
    Getting to the stage where I think I could start priming
    Wheels, drive sprockets, etc assembled as far as I can for the moment.....
    I gave up looking for the missing steering linkages, and made my own from plastic strip - you can just about see them between the front mudguard & the drive housing - once the bodywork & tracks are added they will be invisible ( unless you pick it up! ). No filler used yet, fit is good, but very small pieces makes for difficult handling. You wouldn't have a chance of making this without a decent set of tweezers!
      • 18926
      That looks suitably busy Dave. Looks like you certainly get your money’s worth with this kit!
        Looking forward in the instructions, I could do a lot more assembly, before priming. So, the load bed - a suitably complicated assembly
ID:	1163269Click image for larger version
        Note the 2 holes & slot in the floorplate to the right.
        Instructions - stage 2
        Gearbox with levers added OK
        BUT, then in stage 25Click image for larger version
        The load bed is miraculously added - over the steering column & 3 levers from the gearbox!!!!. I did attempt this, because the instructions said it was possible. It isn't! I will simply cut the levers off flush with the gearbox & reattach afterwards - this is the first instruction error I've found so far..................
        I haven't decided whether to build the model with the 37mm deployed for action, or transport - the difference being the fold down sides of the load bed - I'm in two minds!
        • Gary MacKenzie
          SMF Supporter
          • 1057
          • Gary
          • Forres , Moray , Scotland
          #49
          if that is supposed to work the round holes for the gear sticks would need to be bigger , which I would have thought they would be unless the travel distance and angle is very small on the real vehicle
          Photo for discussion purposes only.
            Decided to do the model in action form - this just means putting the load bed sides horizontal............
            Thinking on it, I reckon these are the largest single piece bits of PE I've ever used so far, and very appropriate - how else would you depict them? The 'hinges' are all butt joints, so I've reinforced each with a drop of CA.
            I think I'm about ready to do some priming, I've thought this before, but kept on finding bits I could add.....
            Dave.
            • RonGlass
              • 801
              #51
              [ATTACH=CONFIG]n1163303[/ATTACH]
              Dave.
              Dave, is there a particular primer that you prefer ? I've grown quite fond of the Mr. Surfacer 1500 Spray , but it is pricy stuff.
                Ron,
                I'm using AK primer at the moment, I've used others, but this seems best for me at the moment
                • RonGlass
                  • 801
                  #53
                  Ron,
                  A while back I bought a bottle of Mr. S 1500 that's supposed to be airbrushable but I'm too leery to try it in my Iwata. Other brands, sure, but the lacquer ....
                    Ron,
                    I only use acrylics, both for brush & a/b - enamels & lacquers leave far too much smell ( I live in a mid-floor flat ). I once used some Alcad II, and I reckon it took a week for the fragrance to dissipate!
                      Primed overall, then basecoated the chassis & wheels
                      I wasn't intending to basecoat the loadbed, but I still had a bit of paint left in the airbrush.
                      I reckon I've sorted the mix of the ICM paint - it took a few attempts!. It sprays very nicely, no problems with tip drying, I'm spraying at about 1.5 bar. The ICM paints are 12ml jars, and I reckon you could cover 2 medium sized tanks ( ie Pz.IVs ). I've wasted a bit trying out the mix, but it will cover this large Sd.kfz.7, trailer & gun, and maybe a tiddler, like a Pz.I
                      What is now looming on the horizon is the individual track links.............
                        All the roadwheel tyres brush painted
                        Boring! Some good music on & no interruptions!
                        Next, probably even boring - the assembly of the tracks. I can't assemble them my normal way, as they don't have a useful guide rib. I'm going to have to try several ways, to see which is least fiddly......................
                          Working up to the tracks - road wheels added, but the drive sprockets will be added when the tracks are being assembled
                          The links............................
ID:	1163463Click image for larger version
                          These are very difficult to handle, the first one I cut off the sprue pinged out of my tweezers, never to be seen again.
                          I had a think on how I could I could make things easier - the sprue layout is such that with careful cutting, you can join 4 links at a time, the sprues allowing easy handling
                          Once you have links jpined, you can continue to build up the straight runs
                          I'll still have to build up the links on the drive sprockets individually, and add the tread blocks, but it does speed things up. This only works, of course when the sprue layout is suitable!
                          • minitnkr
                            Charter Rabble member
                            • 7549
                            • Dayton, OH USA
                            #58
                            Neat solution. Coming along nicely.
                              That’s a very good idea, keeping them on the sprue while you assemble them.
                              • scottie3158
                                • 14214
                                • Holbeach
                                #60
                                Dave,
                                Nice idea.
