This the next build on the bench and something a little different as the title suggests this is the 90/53 AAA mounted on the Lancia 3 Ro truck. for those who may not know the reason there are two numbers in the ordnance(Gun) title the first number is the calibre the second number is the length of the barrel given in calibres for example it is a 90mm gun and the length of the barrel is 53 x 90mm .....4,700mm.
This is only my second IBG build. On opening the large box you are faced with 17 sprues moulded in light grey styrene. the plastic is quite soft with very large gates and a bit of flash but nothing to bad. Also included are 2 clear sprues, 1 bag of wheels, 1 sheet of PE and finally a decal sheet.
The build will be mainly out of the box with a little scratch here and there using the reference material I have, at this point I must thank Prichard1 (Paul) for sending me a CD with a lot of useful pictures.
I have made a start on the engine and will be adding a little detail as I will be having the bonnet open as was often the case.
Hope you can join me along the way.
cheers Scottie
