Rye Field Model (RFM) 1/35 Pz. IV Ausf J kits 5033 (2 in1 ) & 5043 (full interior)
    Originally posted by Panzerwrecker
    It's a bit daft that you are unable to fully build the rotating floor assembly due to just a a few items and the all important brackets on sprues only provided with their interior kit.
    How hard are those to scratchbuild, though? And/or: Has anybody thought of copying them as 3D-printed parts?
      There is no need to scratch the parts
      • Panzerwrecker
        • Mar 2022
        • 575
        • Los
        • Wales, UK
        #33
        Originally posted by Magneto
        Don’t quote me as I’m not yet invested in this kit but try this (some interior parts are even duplicated);
        [ATTACH=CONFIG]n[/ATTACH]
        [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
        Thanks Paul
        I will scour over the 5033 kit to see if all the turret parts are scattered around the sprues. I'll post up what I find as it would be a bonus if they are included
        • Panzerwrecker
          • Mar 2022
          • 575
          • Los
          • Wales, UK
          #34
          I'm going to check all the sprues now as the turret parts might well be included and unlike the interior kit, spread over different sprues. I'll post up my findings ASAP
          • Panzerwrecker
            • Mar 2022
            • 575
            • Los
            • Wales, UK
            #35
            I've just noticed this thread should be in the armour section and not artillery:flushed:. Can a moderator please correct my error?
              Thanks Paul
              I actually have 2 of these kits (because there are 2 fairly distinct options) so would be interested to know.
              Another strange one is that there is another RFM kit that has the same situation - not an interior kit per se but had the turret interior as ‘extras’.
              The Tiger I initial (the winter cam box art - but I’m sure the other initial is the same set up)
                Unfortunately, as soon as I snipped my turret schurzen panels off the sprue gates it was apparent that both the front sections bowed inwards quite badly. I left them overnight under a weight, but they simply sprang back the next day when the weight was removed! I am hoping that a touch more manipulation and the fixing of the brackets to the turret will straighten them out.
                Have you tried reasonably hot water? This is a bit of an abstract art - so best practice on a piece of scrap
                • Panzerwrecker
                  • Mar 2022
                  • 575
                  • Los
                  • Wales, UK
                  #38
                  Thanks for the tip, but I havn't due to me attaching all the brackets to them:rolling: I really should have tried before attaching them, and after the weights I put on them overnight didn't solve the issue.
                  I'll get em straight somehow
                  • Panzerwrecker
                    • Mar 2022
                    • 575
                    • Los
                    • Wales, UK
                    #39
                    OK, so I've done much scouring off both the instructions and sprues of both kits (5033 & 5043) and not all the turret interior parts in interior kit 5043 are provided on kit 5033 sprues. Some are though, and I'll admit I did not notice them, as many have different part numbers and are located on different numbered sprues. (thats my excuse anyway:face-with-head-bandage
                    Heres what I found checking both kits contents
                    Starting off with the sprue count, both kits share some identical sprues. These are:
                    • A x 1
                    • B x 1
                    • C x 2
                    • D x 2
                    • E x 1
                    • F x 1
                    • G x 1
                    • H x 1
                    • J1 x 1
                    • J4 x 1
                    • K x 1
                    • N x 1
                    • W x1 clear
                    • YA x 1 PE
                    • YB x 1 PE
                    • Tracks and poly caps
                    Sprue R x 1 is in both kits but contain different parts (sprue R in kit 5033 is much larger and contains many more parts)
                    Kit 5033 has an extra sprue J2 x 1 which just contains parts for the Artillery Observation vehicle
                    Kit 5043 contains x 14 additional sprues including:
                    • L x 1
                    • M x1
                    • P x 1
                    • Q x 1
                    • S x 1
                    • T x 1
                    • U1 x 1
                    • V x 1
                    • X x 1
                    • XA x 1
                    • Y x 1
                    • Z x 2
                    • 'Clear parts' (Replacement hull and turret parts for showing off the interior)
                    Turret interior parts included on kit 5033 sprues but not called out in the instructions, include:
                    5043 kit part No & equivalant 5033 kit part No
                    F27 - F6 or clear part W13
                    F8 x 2 - Same
                    S15 - R31
                    Z27 - R27
                    S20 - R4
                    W11 - Same
                    W9 - Same
                    X27 - F5
                    X28 - F4
                    F18 - Same
                    F33 - Same
                    X2 - F24
                    X48 - R14
                    F37 - Same
                    (for placement see instruction sheet pics below)
                    There are 31 turret interior parts contained on sprue X x 1 in interior kit 5043 that are not available on any sprues in kit 5033.
                    Although you get a turret floor (part F33) and a few other items which I assembled and posted above, you would still need to scratchbuild three significant parts to connect it to the lower turret moulding. These parts are marked Z32 x 2 and X1. That still leaves twelve other vital parts missing from the rotating turret floor assembly.
                    Turret interor assembly pics from interior kit 5043
ID:	1214802Click image for larger version
                    Please correct me if I've mistaken any info.
                      OK, so I've done much scouring off both the instructions and sprues of both kits (5033 & 5043) and not all the turret interior parts are provided on kit 5033 sprues. Some are, and many have different part numbers. (details below)
                      • A x 1
                      • B x 1
                      • C x 2
                      • D x 2
                      • E x 1
                      • F x 1
                      • G x 1
                      • H x 1
                      • J1 x 1
                      • J4 x 1
                      • K x 1
                      • N x 1
                      • W x1
                      • YA x 1 PE
                      • YB x 1 PE
                      Sprue R x 1 is in both kits but contain different parts (sprue R in kit 5033 is much larger and ttcontains many more parts)
                      Kit 5043 contains x 13 additional sprues including:
                      • L x 1
                      • M x1
                      • P x 1
                      • Q x 1
                      • S x 1
                      • T x 1
                      • U1 x 1
                      • V x 1
                      • X x 1
                      • XA x 1
                      • Y x 1
                      • Z x 2
                      To add turret parts included on kit 5033 sprues but not called out in the instructions include: (for placement see instruction sheet pics below)
                      5043 part No Equivalant 5033 part No
                      F27 F6 or clear part W13
                      F8 x 2 Same
                      S15 R31
                      Z27 R27
                      S20 R4
                      W11 Same
                      W9 Same
                      X27 F5
                      X28 F4
                      F18 Same
                      F33 Same
                      X2 F24
                      X48 R14
                      F37 Same
                      There are 31 turret interior parts contained on sprue X x 1 in kit 5043 that are not available on any other sprues in kit 5033
                      However , almost all of the rotating turret floor can be made but it requires two vital brackets (parts Z32 in kit 5043) to attach it to the lower turret moulding. These would need to be scratch built to utilise the turret floor parts available. Two othe small parts on the floor require scratch building along with the addition of gas masks, but thats it.
                      [ATTACH=CONFIG]n1214801[/ATTACH][ATTACH=CONFIG]n1214802[/ATTACH]
                      [ATTACH=CONFIG]n1214803[/ATTACH]
                      Great report! Thanks! Not sure if you checked clear sprue? They have TCs chair and supports (I don’t have kits in front - stashed away. But here could be a plot twist….
                      Can you look at that missing ‘turret support-esque’ piece I kit 33? Vis;
                      [ATTACH]497639[/ATTACH]
                      • Panzerwrecker
                        • Mar 2022
                        • 575
                        • Los
                        • Wales, UK
                        #41
                        Yes, I did check and include the clear sprue W x 1
                        The circled part on sprue V1 is not on any sprues in kit 5033
                        • Panzerwrecker
                          • Mar 2022
                          • 575
                          • Los
                          • Wales, UK
                          #42
                          I will now add any worthwhile turret interior parts that kit 5033 has available and might attempt to scratch build the three crucial missing brackets that connect the rotating turret floor (parts Z32 and X1 in kit 5043)
                            [ATTACH]497640[/ATTACH]
                            Yes it is! Lol
                            And here it is on the sprue map;
                            [ATTACH]497641[/ATTACH]
                            If it really isn’t in your kit (do you have ‘V’ on your map?). I’ll wait before reaching a conclusion[ATTACH]497642[/ATTACH]
                            • Panzerwrecker
                              • Mar 2022
                              • 575
                              • Los
                              • Wales, UK
                              #44
                              Yes it is! Lol
                              There is no sprue V x 1 in kit 5033. That sprue is from interior kit 5043 or I've been robbed!!!! Your pic also shows a small Sprue R which is way bigger in kit 5033
                              I'll download the sprue count pics for each kit shortly
                              • Panzerwrecker
                                • Mar 2022
                                • 575
                                • Los
                                • Wales, UK
                                #45
                                Don't mix up the sprues for both kits or you'll be in need of a few paracetamol
