Takom 1/35 SADF G6 Rhino
  • Snowman
    • Oct 2014
    • 2098
    #31
    Now that I have finally dragged the Eland across the finish line, I'm back onto the G6.
    I painted the diver, really pleased with the Vallejo acrylics and painted the interior of the cab.
    Painted the armoured glass was eventful, 1st attempt looked like something from an Irish convention.....emerald green!
    2nd attempt was an improvement.
ID:	1233495 Click image for larger version
ID:	1233496 The driver will be fitted and the hull buttoned up.
    Till next time.?
    • Snowman
      • Oct 2014
      • 2098
      #32
      The driver is in.
ID:	1233946 Now the buttoned up hull looks something like an AT-AT walker...?
ID:	1233947 Now time to mask the windows and add all other bits, then onto the turret.
      Till next time.?
      • Steven000
        • Aug 2018
        • 2818
        • Steven
        • Belgium
        #33
        Nice progress Gavin, the driver fits right in, have fun
        • Snowman
          • Oct 2014
          • 2098
          #34
          After some research ( staring at a bunch of old photo's for hours..?) I realised the new variant had extra vents and holes that need plugging.
ID:	1235457 Also removed some splash shields. Did a dry fit on the revised gun mount, nearly finished!
ID:	1235458 Click image for larger version
          Oops, double image.
          Oh well, till next time.
          • scottie3158
            • 14189
            • Holbeach
            #35
            Very nice mate. Missed this uptil now but will follow along.
            • Snowman
              • Oct 2014
              • 2098
              #36
              The work continues incrementally, raided my motorbike detailing bits and found some bolts that are easier to apply than the Meng plastic bolt heads.
ID:	1237230 Marked out revised gun mount.
ID:	1237232 Click image for larger version
              Dry fitted with the bolts.
ID:	1237233 started the commander's copula, not really a fan of the clear construction that requires some delicate masking.
              Till the next update. ?
              • Snowman
                • Oct 2014
                • 2098
                #37
                I'm back from Telford, great event, a bit of controversy about the lack of proper commercial vehicle category for trucks and the like, hopefully that get ironed out.
                Finally decided to bite the bullet and start building the headlight shrouds.
                My first attempt with a cardboard prototype was quite close to the mark.
ID:	1240601 Then onto prototype 2 in plasticard, just hope it will bend easily.
ID:	1240602 Till the next update. ?
                  • 22768
                  #38
                  Nice to see you back at this one. Some outstanding work so far.
                  • Snowman
                    • Oct 2014
                    • 2098
                    #39
                    Four prototypes later......?‍?
ID:	1241175 I think I have finally cracked it. The 0.25mm plasticard did the trick, it did not fracture and snap during bending.
ID:	1241176 Now for the second unit.
                    Till the next update ?
                    • Steven000
                      Steven000 commented
                      Editing a comment
                      Yes you nailed it Snowman ? the headlight looks great, nice scratching, cheers
                  • scottie3158
                    • 14189
                    • Holbeach
                    #40
                    Very nice work indeed.
                    • Snowman
                      • Oct 2014
                      • 2098
                      #41
                      Well, I think that's done. Just the side view mirror arms are missing.
ID:	1241435 Very happy with the end result.
                      • Snowman
                        • Oct 2014
                        • 2098
                        #42
                        Yup, the front end is finished and ready for paint.
ID:	1241541 Click image for larger version
ID:	1241542 I've decided to put it on a similar base as the "Klein boet -Ou boet" build. Already have atopical photo selected.
                        Till the next update?
                        • scottie3158
                          • 14189
                          • Holbeach
                          #43
                          Some lovely detail looking forward to the next update.
                          • Snowman
                            • Oct 2014
                            • 2098
                            #44
                            Finally grasped the nettle and modded the commander.
ID:	1243970 Click image for larger version
ID:	1243971 I think it looks quite natural. Just gotta sort out the bone dome, the SADF version is simpler without the flared ears for the cans.
                            Wishing all a happy festive break and I'll be seeing you in the new year.?
                            • Snowman
                              • Oct 2014
                              • 2098
                              #45
                              I changed the helmet to something closer to the SADF variant which looks more like a load masters headgear.
                              Anyway, I am pleased with the American style dome.
ID:	1244917 Till next time.?
