Started building the 2nd Aerosan, I`ve got it to the stage where it`s now ready for painting, and I think it will look very similar to the one already painted, lots of wear and tear, with an old war horse look about them both, will update again once this one is finished
Just a small up date on the build, started by smearing plaster on the board to build up the groundwork, once this had completely dried scenic glue was sprayed onto the plaster and scenic snow was sprinkled until I got the affect I was after, then a couple of coats of scenic glue was sprayed on top of the snow, as this was drying the Aerosans were dragged on top of the snow to make the track lines in he snow.
Going to add some grass, maybe a wooden fence or a snowman, don`t know yet, but will update again when I have made my mind up
Just a small update on the dio, the two Aerosans are nearly completed, just one or two small bits to add, mainly around the ski`s that I`ve added to the Aerosans and then the figures these are from Miniart.
The base has had more snow added along with tufts of grass dotted about the base, I have got to add more static grass and maybe a bush or two and more snow, nearly done, hope you like it so far
