Military truck and transport trailer
  • Jukebox64
    • Aug 2024
    • 161
    So for my birthday, my son and his wife bought me this. I’ve been working two days and this is all I have done.
  • HAWKERHUNTER
    • Feb 2012
    • 1510
    • Steve
    • Halifax, West Yorks.
    Well that should keep you busy for a while. In 1:35 scale, you are going to need some shelf space for it. Cracking looking kit.
    • Jukebox64
      • Aug 2024
      • 161
      There’s 1478 parts!!!
        • 15630
        That should keep you busy for a while. Two foot plus in length when built - gonna need a big shelf ?
        • Jukebox64
          • Aug 2024
          • 161
          Usually, I do 1/25 or 1/24 scale, cars or trucks, but my son noticed that I was building them pretty fast so he thought he would give me a challenge. Plus, I’m a former marine that served in operation desert storm so I have experience with these vehicles that I’m building now.
          This thing even came with a lot of PE parts, something else I’m fairly new at and haven’t quite figured out how to attach them firmly..
          • Ernie
            • 144
            • Ernie
            • New Hampshire
            WOW! Now that is an impressive kit! This will be fun to watch come together.
            • Jukebox64
              • Aug 2024
              • 161
              I have no experience with PE parts and this kit has a lot of them. I’m learning as I go..
              • scottie3158
                • 14192
                • Holbeach
                Hi, if I can offer a bit of advice with the PE. Clean thoroughly to remove any oils use hot soapy water and let dry. When you have removed the part gently score the mating face with the tip of a sharp blade and the point on the vehicle where it will go. Then use a good CA glue. Don't be tempted to use all the PE just because it's there. Quite often its no better then the kit part and its very two dimensional so for example to make handles use wire instead. HTH
                Scottie
                • Jukebox64
                  • Aug 2024
                  • 161
                  Thanks, brother advice. I have already learned that I’m not going to use all of these PE parts. Some of them are more for looks than anything else and I’m building a military style vehicle that will be painted desert sand color all over.
                  • Jukebox64
                    • Aug 2024
                    • 161
ID:	1236213 Click image for larger version
ID:	1236214 Click image for larger version
ID:	1236215 Click image for larger version
ID:	1236216 So far, here’s what I’ve gotten done to the tractor.
