Tamiya US 6x6 Fuel Truck 1/48
    Hello
    This isn't much of a build thread because I already mostly built it since it goes together quickly but here it is anyway:
    [ATTACH]104795.IPB[/ATTACH]
    To complement the truck and the diorama that I will put it on, I got the tamiya jerry can kit
    [ATTACH]104794.IPB[/ATTACH]
    The chassis was easy to assemble, I airbrush it olive drab then I picked out the details with flat black
    [ATTACH]104808.IPB[/ATTACH]
    The cockpit did not have many details but you won't see much of it anyway in the finished model
    [ATTACH]104807.IPB[/ATTACH]
    Unfortunately, there is no "engine". I was hoping that the hood could be opened
    [ATTACH]104806.IPB[/ATTACH]
    Once assembled, I airbrushed the front of the truck with black to create a sort of pre-shading
    [ATTACH]104804.IPB[/ATTACH]
    The pre-shading seems to have worked after airbrushing a thin coat of olive drab[ATTACH]104803.IPB[/ATTACH]
    Cockpit glued onto the chassis and a bit of dry brushing with chrome silver to create a worn look
    [ATTACH]104834.IPB[/ATTACH]
    The wheels were a bit of a pain and took a good couple hours to paint
    [ATTACH]104802.IPB[/ATTACH]
    But once finished and glued into place, they looked really cool
    [ATTACH]104793.IPB[/ATTACH]
    To create the fuel hose, metal wire is inserted into a rubber tube so that later you can adjust its position easily.
    [ATTACH]104792.IPB[/ATTACH]
    Once again, pre-shading
    [ATTACH]104801.IPB[/ATTACH]
    Assembling the fuel cistern
    [ATTACH]104800.IPB[/ATTACH]
    the roof and a few bits and pieces glued into place
    [ATTACH]104799.IPB[/ATTACH]
    Sidewalls installed and everything else painted. Unfortunately, most of the detail inside the hose compartment won't be seen because of a closed hatch.
    [ATTACH]104796.IPB[/ATTACH]
    Too much weathering?
    [ATTACH]104798.IPB[/ATTACH]
    So far, so good...
    [ATTACH]104797.IPB[/ATTACH]
    I did not want to airbrush a clear coat because when I tried it on the chassis, it made it too dark and softened a lot of the detail. Also, it is hard to get the gloss back to a nice flat finished later on. For this reason, I decided to apply decals straight onto the paint. As you can see, it did't work because the paint would get stained by the water and change its tone. I decided that until I knew of a solution to this, I will not apply any more decals. Can anyone help?
    [ATTACH]104791.IPB[/ATTACH]
    I think the bottom turned out well
    [ATTACH]104835.IPB[/ATTACH]
    When placed in the P-47 diorama, obvious flaws such as a lack of decals are not very noticeable.
    [ATTACH]104836.IPB[/ATTACH]
    The build is not finished yet, I need to make the figures and I will try to somehow sort out the decals, maybe rub on transfers?
    I will be away for about a month so I won't be able to build the great scale figures that come with this kit but it will be the first thing I do when I come back.
    See you next time
  • takeslousyphotos
    • Apr 2013
    • 3900
    Great Stuff Ivan ....... A good clean build. I like that a lot.
    Peter
      Looks good & a nice view of the transmission drives. A job well done.
      John.
        I like this a lot.
        scott
        • monica
          • Oct 2013
          • 15169
          nice clean build you have Ivan i do like it,
            Hello every one, got back from my holiday with renewed enthusiasm to continue scale modelling! I order to complete my P-47 diorama, I assembled and painted three of the figures included in the refuelling truck but unfortunately I lost one of their heads so now its down to two.
            [ATTACH]107718.IPB[/ATTACH]
            The clothes were painted khaki, the helmet olive drab, booths flat black and the skin in Tamiya flesh
            [ATTACH]107715.IPB[/ATTACH]
            I love how tamiya included a rubber refuelling line, it adds realism and is really easy to adjust.
            [ATTACH]107716.IPB[/ATTACH]
            Along with the figures, I painted some of the miscellaneous parts from the Tamiya WW2 jerry can and supplies set and added them to the scene.
            [ATTACH]107717.IPB[/ATTACH]
            Is a shame that the driver won't be seen once I put the doors back on.
            Can't wait to start my next scale model, a Tamiya A-1 skyraider in 1/48!
            See you next time
              • 22769
              Great work Ivan
              • monica
                • Oct 2013
                • 15169
                looks good Ivan nice work so far,
                  Great work, sets off the dio nicely
                    Nice work, glad you found the enthusiasm to finish it. Look forward to the skyraider
