Tamiya - 20mm Flakvierling - Sd.Kfz 7/1 1/35 Scale.
  • takeslousyphotos
    • Apr 2013
    • 3900
    #46
    Wheels are on. That was a bit of a fight (there are caps to go on the centres, and a bit of touching up from "Fight Damage". But I'll leave that until after the tracks go on, in case I need to make some adjustments.) and I've started on the tracks & tyres for the front wheels......... getting things ready for the bonnet to go on.........
    [ATTACH]112756.IPB[/ATTACH]
    [ATTACH]112757.IPB[/ATTACH]
    • grumpa
      • Jan 2015
      • 6142
      #47
      After a bit of dry brushing the rubber to steel detail will come out by itself just use a very dry brush and a light touch PS get a hold of some 'eye shadow brushes' the Mrs. probably has one or two to spare, you will see immediately why I use them....................Jim
      • monica
        • Oct 2013
        • 15169
        #48
        looking good so far,do real like the underside well done,
        • Richi72
          • Sep 2013
          • 1100
          #49
          Great job so far Peter.
          Nice weathering and I would keep Jim's eye shadow brushes in mind, they do make a difference.
          Keep up the great work.
          Cheers Richi
          • takeslousyphotos
            • Apr 2013
            • 3900
            #50
            I will delve into the depths of my missus make up bag. If I get caught I'll blame you.
            • takeslousyphotos
              • Apr 2013
              • 3900
              #51
              Thanks Monica...... I am really enjoying this one. I think, probably more that I have for a few kits I've built.
              • takeslousyphotos
                • Apr 2013
                • 3900
                #52
                Cheers Richi
                Much thanks Richard...........I will be stealing a brush and I also need to go pick up a couple of pigments at the weekend.
                • grumpa
                  • Jan 2015
                  • 6142
                  #53
                  After you use up the brushes she gives you wait till YOU have to go buy some yourselfops:
                  • takeslousyphotos
                    • Apr 2013
                    • 3900
                    #54
                    A little more progress ......... The bonnet is on ( I left the gaps on purpose, as I figured things up there might be a little battered, and a grey wash will highlight that) and Radiator Grill has had a couple of coats of "Smoke Brown Ink" and a dry brush of rust.
                    Tracks are done. Flat Metal grey, Nato black on the pads and a light dry brush of rust on the links. I know the Bosche used some kind of "Anti rust" coating or galvanising or somesuch. But it'd wear for sure so there'd be a bit of rust I reckon........ and the front tyres had had a couple of coats of Nato Black as well.
                    Tomorrow I'll make a start on the interior module.
                    [ATTACH]112910.IPB[/ATTACH]
                    [ATTACH]112911.IPB[/ATTACH]
                    [ATTACH]112912.IPB[/ATTACH]
                    [ATTACH]112913.IPB[/ATTACH]
                    [ATTACH]112914.IPB[/ATTACH]
                      • 22771
                      #55
                      Some very nice work Peter
                      • takeslousyphotos
                        • Apr 2013
                        • 3900
                        #56
                        Thanks Ian, Much appreciated matey.
                        • grumpa
                          • Jan 2015
                          • 6142
                          #57
                          Looking good so far, like the coloring on the tracks, rust tone very convincing
                          • takeslousyphotos
                            • Apr 2013
                            • 3900
                            #58
                            Thanks Jim. Tracks are on now. I had to unclip them and sort of wind them on the drive sprocket and then join them. There was no other way to get the buggers on.............. Build ing this kit with things still im place and doing it in a different order to the destructions is presenting a few challenges.
                              Now that is coming along very nicely peter.
                              Scott
                              • Richi72
                                • Sep 2013
                                • 1100
                                #60
                                great progress so far.
                                I often leave the sprocket wheel of until i put the tracks on. sprocket in the track and then put it over the rest of the wheels and then it the sprocket in place, oh and i do that only with the vinyl ones.
                                waiting for the next update
                                Cheers Richi
