FAMO & Sd.Ah.116
    [ATTACH]32261.vB[/ATTACH][ATTACH]32262.vB[/ATTACH]
    [ATTACH]37164.IPB[/ATTACH]
    [ATTACH]37165.IPB[/ATTACH]
      Looking good John, like the boxes and drums that you have placed in there. As far as I can see the cover for the cab, thinking back to the build I did, ran at a level right the way through, Try using Tissue paper if the netting does not sit right, that once the PVA glue gets into it can be pressed and moulded to how you want it. Failing that Miliput rolled out on a ceramic tile with talc can be stretched to a very thin piece and can then be placed and moulded to the shape you want. Once you have the required shape then let the air do the rest and it should look quite authentic when it is weathered and painted, or should I say painted and weathered?
      Andy
        [ATTACH]32384.vB[/ATTACH][ATTACH]32385.vB[/ATTACH]
        I think i'm getting there.
        [ATTACH]37269.IPB[/ATTACH]
        [ATTACH]37270.IPB[/ATTACH]
          • 18269
          Looks good to me.Ian M
          • geegad
            • Mar 2010
            • 2329
            #50
            Why have I missed this build spent a while going through your pictures John you have done one quality job on this rather large build and the level of detail is quality so much to build but you've put the time into making it look brill
            I will keep up with you now John I've always wanted to build a large famo dio and now ive seen yours I want to do one even more keep it up
              Thank's John for ur kind words, this build seems to go on & on, i just finish a bit then see a pic on the net of a mod and think i could do that & start all over again.
              I seem to be making it ass about tit, should have done my resurch first then the build.
              I dont have a stash of models, if i got it i build it.
              Thaks again John i will try to do this kit justice.
              [ATTACH]32437.vB[/ATTACH][ATTACH]32438.vB[/ATTACH][ATTACH]32439.vB[/ATTACH][ATTACH]32440.vB[/ATTACH]
              Just one or two things to do to this one, will try to make my own canopy.
              [ATTACH]37288.IPB[/ATTACH]
              [ATTACH]37289.IPB[/ATTACH]
              [ATTACH]37290.IPB[/ATTACH]
              [ATTACH]37291.IPB[/ATTACH]
                [ATTACH]32458.vB[/ATTACH][ATTACH]32459.vB[/ATTACH][ATTACH]32460.vB[/ATTACH]
                Wont put camo cover on till i've finished the painting & wethering.
                [ATTACH]37309.IPB[/ATTACH]
                [ATTACH]37310.IPB[/ATTACH]
                [ATTACH]37311.IPB[/ATTACH]
                  [ATTACH]32468.vB[/ATTACH][ATTACH]32469.vB[/ATTACH][ATTACH]32470.vB[/ATTACH][ATTACH]32471.vB[/ATTACH][ATTACH]32472.vB[/ATTACH][ATTACH]32473.vB[/ATTACH]
                  Dam it's BIG over 25" ( 63.5cm).
                  I think theres light at the end of the tunnel. lol
                  [ATTACH]37317.IPB[/ATTACH]
                  [ATTACH]37318.IPB[/ATTACH]
                  [ATTACH]37319.IPB[/ATTACH]
                  [ATTACH]37320.IPB[/ATTACH]
                  [ATTACH]37321.IPB[/ATTACH]
                  [ATTACH]37322.IPB[/ATTACH]
                  • Andy2035
                    • Aug 2011
                    • 730
                    #54
                    Hi John,
                    Many thanks for sharing this build with us, looks amazing...
                    May I as, did the netting come with this kit, if not, could I ask where I could get one please....
                    Kind regards...
                    Andy...
                      Hi andy thanks for the comment on the build it's still got a long way to go.
                      No the camo net was not with the kit but u can get them at VERLINDEN PRODUCTIONS and they come in diferent shades.
                      [ATTACH]32595.vB[/ATTACH][ATTACH]32596.vB[/ATTACH]
                      Look them up on the net.
                      Regards
                      [ATTACH]37438.IPB[/ATTACH]
                      [ATTACH]37439.IPB[/ATTACH]
                      • Andy2035
                        • Aug 2011
                        • 730
                        #56
                        Hi John,
                        Many thanks for the info, I shall have a search for them, also looking forward to following the rest of this build...
                        Kind regards...
                        Andy...
                          Well it's been a very long time since i started this thing & then put it to one side for a rest untill my building skills got better.
                          Well it's about time i finished it as i think my painting skills have inproved a little, as you will see i have made one or two changes to the famo like removing the canopy as this will interfear with the figures in the back.
                          I have had to make the driver & paint him so i can complet the cab, i have some 15 figures to make & paint and im not looking forward to that.
                          [ATTACH]39096.vB[/ATTACH][ATTACH]39097.vB[/ATTACH][ATTACH]39098.vB[/ATTACH][ATTACH]39099.vB[/ATTACH][ATTACH]39100.vB[/ATTACH]
                          John.
                          [ATTACH]43064.IPB[/ATTACH]
                          [ATTACH]43065.IPB[/ATTACH]
                          [ATTACH]43066.IPB[/ATTACH]
                          [ATTACH]43067.IPB[/ATTACH]
                          [ATTACH]43068.IPB[/ATTACH]
                            What an epic build - liking this a lot
                              Looking to be a very impressive build!
                                Just added a little extra to the bonnet (HOOD), will do the same to the open windscreen.
                                [ATTACH]39106.vB[/ATTACH]
                                [ATTACH]43074.IPB[/ATTACH]
