A Summer Schwimm (Tamiya 1/48 Schwimmwagen)
  • Steve Brodie
    • Sep 2014
    • 4652
    Decided to give the 57-2 gun system a break ( http://www.scale-models.co.uk/thread...-3#post-355832 ), all those bits were making me go mad, so got out a recent find, Tamiya’s 1/48 Schwimmwagen. Very nice evening so set up outside with a nice pint of Rekordelig cider, not many parts to this one, so with cutters, tweezers, glue, knife, sanding sticks and galsses on got to work;
    [ATTACH]282328[/ATTACH] [ATTACH]282329[/ATTACH]
    An hour or so later and got to this point;
    [ATTACH]282330[/ATTACH] [ATTACH]282331[/ATTACH] [ATTACH]282332[/ATTACH] [ATTACH]282333[/ATTACH]
    The hardest bit was the canvas cover and the supports, because I am build this so I can remove the top to get inside once sprayed, I assumed that the canvas would fit flush on the body, glad I dry fitted the top to the bottom as its evident it rests on the rear seats, near disaster avoided;
    [ATTACH]282334[/ATTACH]
    Only a few bits to go on and then will be ready for the spray shop and then some weathering. Got a 1/48 scale figure coming from CMK to set it all in a little vignette I have in mind, entitled “damm that handbrake” , but that will be later. back to the monster gun on Monday
  • col68
    • 1505
    I've just bought the 1/35 scale tamiya schwimmwagen. I'll be following your build steve
    • Robert1968
      • Mar 2015
      • 3596
      This is looking Fab Steve. I've seen this many times before and always thought it would look nice in a dio fording a river etc
      I'll be watching this one for ideas
      Nice clean build and lovely pics too
      Regards
      Roebrt
        I never build a 1/48 model, almost I don't remember it,.....and I'm really wishing to do it a go!
        This one could be a good candidate, nice choice
        • Steve Brodie
          • Sep 2014
          • 4652
          These Tamiya kits in 1/48th scale are awesome. High levels of detail, relatively easy construction and typical Tamiya shake and bake results. Well recommend
            • 22770
            Great start Steve. I've just completed the Frog 1/48 Schwimmwagen in the Cosford under a fiver GB.
            • monica
              • Oct 2013
              • 15169
              nice start to this wee one,Steve,I do have one as well,
              dose look good and nice detail,
              • Steve Brodie
                • Sep 2014
                • 4652
                All finished, dry fitted top to base and very good fit, split along the weld line. Attached a couple of painting handles ,
                The highlighter marks on the jars as so I can see straight off they are pre thinned (now) and ready to airbrush.
                [ATTACH]282389[/ATTACH]
                [ATTACH]282388[/ATTACH]
                • monica
                  • Oct 2013
                  • 15169
                  looking good Steve,will be waiting on color,
                  • Steve Brodie
                    • Sep 2014
                    • 4652
                    Got some paint on it tonight , first a light gray base coat, followed by NATO black into the crevices and around the lower hull and the insides
                    [ATTACH]282487[/ATTACH] [ATTACH]282488[/ATTACH]
                    Them the first coat of German grey misted on and with the airbrush pressure lowered started to add highlights to the higher points and panels
                    [ATTACH]282489[/ATTACH] [ATTACH]282490[/ATTACH] [ATTACH]282491[/ATTACH] [ATTACH]282492[/ATTACH]
                    Wheels received the same treatment.
                    [ATTACH]282493[/ATTACH]
                    • monica
                      • Oct 2013
                      • 15169
                      looking good,Steve,
                        • 22770
                        Cracking work so far Steve, it's coming along very nicely.
                          Cool
                          • Steve Brodie
                            • Sep 2014
                            • 4652
                            Painted the 'detail' bits last night, the wooden boards, oar, rusty exhaust and the canvas cover. Highlighted with good old dry brushing and dark wash into the recesses, also started work on the shovel. Chipping, dusting up plus some light mud next, followed by some foliage for camouflage.
                            [ATTACH]282518[/ATTACH] [ATTACH]282519[/ATTACH] [ATTACH]282520[/ATTACH] [ATTACH]282521[/ATTACH] [ATTACH]282522[/ATTACH] [ATTACH]282523[/ATTACH]
                              Mmmm.....I really like your work there, Steve.
