Afternoon all. A nice little build this, it went together beautifully, virtually no flash, and just a few ejector marks most of which are hidden anyway. I undercoated the whole thing in Humbrol 29 from a rattle can before building, and then brush painted it as I went along. Mostly Humbrol enamels but some acrylics too. Basically whatever paint I had that was the right colour! SCC 2 Service Brown is a mix of Hu 29 and 98, the SCC 14 camo pattern is Revell Anthracite acrylic. The canvas tilt was given a wash of 98 then dry brushed with a mix of 29 and white.
First off the chassis and engine. Don't know why I painted the engine as it's completely hidden on the finished model!
[ATTACH]304460[/ATTACH]
Next the wheels were fitted and the rear body built. It's not glued in place at this point.
[ATTACH]304461[/ATTACH]
Construction finished at this point and painting nearly done. Pin washes and fine details being picked out. I made a few alterations along the way - I cut the windows from the top of the doors as this allows you to actually see the interior, and I removed the cupola from the roof of the cab.
[ATTACH]304464[/ATTACH]
Windscreen made with Glue 'n' Glaze as with the side windows removed the kit part is way too thick. It dried a bit rippley but to be honest no worse than the kit transparency.
[ATTACH]304465[/ATTACH]
