Land-Wasser-Schlepper No. 1071
Here’s a good photo of the real badge, with thanks to the person who mentioned its existence to me:
[ATTACH]451857[/ATTACH]
And he also passed on this (colorised) photo of my subject:
[ATTACH]451858[/ATTACH]
This was taken at Le Havre, by the way.Comment
I want to also put one or two on deck, preferably dressed like in the photo of the real vehicle at the start of the thread. One in an overall is not a problem, but an officer in long coat is not something I have parts for in my figures stash (yet).
Well, he is the one most at risk of falling overboard, I suppose, up in that little observation point in front of the funnel.
You can tell it’s knotted rope, but I’m now thinking a good representation can probably be made with something like rolled-up bandages, or maybe finer mesh than that.Comment
It’s now finished as far as I want to build it before spraying, I think:
[ATTACH]452025[/ATTACH][ATTACH]452026[/ATTACH]
As I suspected, it goes together very quickly once you’ve gotten past the interior
Here’s a quick comparison with another amphibian under construction:
[ATTACH]452027[/ATTACH]Comment
Motorboat on tracks is what’s come to my mind more than once. It really does seem to be like they put a boat designer and a tracked vehicle designer together and said, “Make us an amphibious vehicle.” I mean, it’s even got portholes rather than vehicle-style windows, as if they expected it to spend most of its time in the water.
With a coat of Mission Models Panzergrey RAL 7021 applied:
[ATTACH]452174[/ATTACH]
The insides of the hatches were apparently the same ivory colour as the interior, so I sprayed them first with more of the Portland Stone before applying the grey to the outside; some touching up will be required, though. I forgot to paint the inside of the door, so that will need to be brushed as well.Comment
It is, which is why I asked a greater authority about this particular oneMy own conclusion, based on the photo at the start of this thread, was that the insides of the front hatches were probably light in colour (and thus, almost certainly ivory like the interior) but because they’re hard to see I wasn’t sure. The fellow who supplied me with the colour picture of LWS 1071 and the photo of the badge said that they seemed to be pale in colour in several other photos too, so I decided to go with that.
You’re right that most hatches of vehicles are painted the outside colour on the inside, though not absolutely always. American LVTs, for example, had white on the insides of the driver’s hatches too. (Which, of course means absolutely nothing with regards to the colour of those on the LWS, but it’s an odd parallel between two amphibious vehicles)
Today, I sprayed lighter patches into all of the panels to highlight them:
[ATTACH]452374[/ATTACH][ATTACH]452375[/ATTACH]
Simply with the base colour from Mission Models with some Vallejo Model Air white mixed in to give a medium grey. It turned out I had mixed exactly enough for what I needed to spray, so that was fortunate
Less fortunate is that the Mission Models paint doesn’t seem to like water much. Before spraying the lighter blotches, I had tested a couple of washes on the underside to see which would look better. This is what happened:
[ATTACH]452376[/ATTACH]
Ignore the lighter grey, that was a test to see if it had the right shade. Below the lighter grey is Mig Dark Wash straight from the bottle, above it is the same wash but thinned with some water, and at the bottom is Tamiya flat black thinned with water. As you can see, with both of the ones I thinned with water, the paint was removed from the ribs and also a bit around them. At the very top is where I then tried just brushing with water, no paint, and the same thing happened
I think I’ll need to put a coat of varnish over this model before trying to add any kind of wash or other effects, else it looks like the grey base coat might well wear off.Comment
